Z1 900 mono shock project
  • j236racing
  • j236racing's Avatar Topic Author
24 Nov 2011 21:51
#490053
Heres some quick pics of my project, 75 z1 900 motor, frame was a junkyard find, swingarm, frontend, and brakes and wheels are from a 1988 honda hurricane 600, hope to have done by spring? Funny story the the frame and motor that came in
it, the frame had been stretched and raked with a locked up motor with a good back cut tranny, a buddy was at the scrapyard dumping a old lawn mower and seen it layin in a pile, he traded the lawn mower for it, I got it for getting his HD goin this spring, so ive piecing it together,
Lifes a garden, DIG IT!!!
  • Boostable
  • Boostable's Avatar
Re: Z1 900 mono shock project
24 Nov 2011 22:07
#490056
Nice... I will be tagging along on this one. Look forward to seeing the progress.
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
  • wireman
  • wireman's Avatar
25 Nov 2011 01:01
#490062
Attachment popcorn_2011-11-24.jpg not found
  • racer54
  • racer54's Avatar
25 Nov 2011 02:54
#490074
Sure hope you brought more then one box of popcorn...others are sitting watching too and my dear mother always said you shouldn't eat in front of people unless you bring enough for everybody! :whistle: :lol:
  • Zedone
  • Zedone's Avatar
25 Nov 2011 17:02
#490116
Nice looking project.
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • ramtough_63
  • ramtough_63's Avatar
25 Nov 2011 17:52
#490122
nice project hope to see more pictures i am a picture junkie!!!
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • j236racing
27 Nov 2011 03:56
#490300
little update: z1 motor runs, good compression and popped right off (who knows how long its been since it ran last, as it was a parts bike motor)with the all the ignition parts out of the 79 kz1000st parts bike I got,the rebuilt mikuni 28's with pods and pro pipe, needs some heavy tuning but it runs,(only thing I had in the garage for gas was VP110) front forks are fighting me, i put some seals in them, and added spec oil and air (air over oil forks, damn honda)forks dive and dont rebound, I can bottom them out by hand? still workin on a brake pedal and mounting the honda rear master cylinder. Im gonna try to run the honda 600 sprockets see how it goes? Did the electrolosis trick on the tank will get some pics up soon!
  • testarossa
  • testarossa's Avatar
27 Nov 2011 04:16
#490301
Yep, these big bore Kawasakis just want to run. My 1000 fired right up after sitting for at least 15 years on the first try. Took a couple of seconds for the gas to work it's way from the tank, fill the float bowls and whammo, we have ignition. I had it bench synced, idle screw setting was a guess, timing was set static, jetting was a guess due to pods and 4 into 1, but the old girl just wanted to run. Damn good feeling too.
Good luck sorting out your forks. I would guess that something internal is wrong if you can bottom them out by hand. That should not be possible. Needs to be able to support 700-800 lbs of bike and rider under hard braking which is well more force than you can generate by compressing forks by hand. Unless you are the Incredible Hulk. In which case I don't want to make you angry, I won't like you when you're angry. :silly:
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • j236racing
22 Dec 2011 00:42
#494255
Little update. Havent had much progress on the build. got the battery box put in, still fighting the frontend, Im having steering stem issues now, but got to use some halfass engineering!! Slowly chipping away at it, Ill get some pics up after xmas
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
22 Dec 2011 06:58
#494298
Like the build but, isn't there a couple frame rails missing? Speaking of the 2 running from the neck back under the backbone, the rails that the coils and tank mount rubbers mount on. That frame but be a little flexy without them.
Les Holt
  • dejavoodo41
  • dejavoodo41's Avatar
22 Dec 2011 18:28
#494357
I'll be watching this one since I happen to have 1000 Hurricane frame front end and wheels that I was thinking of using on my bike.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • wireman
  • wireman's Avatar
23 Dec 2011 00:23
#494389
les holt wrote: Like the build but, isn't there a couple frame rails missing? Speaking of the 2 running from the neck back under the backbone, the rails that the coils and tank mount rubbers mount on. That frame but be a little flexy without them.
Les Holt
how did i miss that? :sick: :woohoo:
