retro gpz 750 modification
- RTGPZ
13 Nov 2011 17:05 - 14 May 2012 12:57Attachment IMG_20120513_152131.jpg not found
took a gsxr 600 07 rear swingarm assembly and turned the oroginal swingarm bolt bushing down to fit into 07 swingarm brg and made 2 shouldered washers to fit brgs on 07 gsxr swingarm.Used 07 shock and linkage ,then made upper mount. All origonal shock mounts were cut away and made my own.I also added foot pegs from 01 fzr r1..the taillight is from a 01-05 fzr 1000.As for the chassis i reinforced with a x member above swingarm,and triangled the area behind neck.
Front forks are off a 00 gsxr 750 I had to machine stem on lower triple tree to fit tapered brgs worked great,i machined threads on gsxr stem to allow nut to thread down farther.the only problem was having to move headlight bracket down 1 in and reweld to neck. this allowed clearance for clip ons. I made stops for the forks with 1/4-20 allen bolt counter bored.As for brakes i'm using 01 zx7 6-piston calipers because gpz is not a light bike.
I decided to work on my engine!My future plans include a 810 kit,cams,carbs,port work,but for this year coming in 2012 i'll enjoy the stock motor. I put a 6 speed trans in from 84 gpz550 using all parts from the 550,and all the info from kz forum. it went in pretty slick the only update is you dont have to use 550 trans cover to keep neutral safety switch. just relocate the taller pin on shift drum which is under neutral safety plate to the 750 safety switch location on trans cover for gpz750.with a gasket seal kit from dennis kirk I'll be putting motor back together soon. Well bottem end of motor back together waiting on boring for piston kit back. Did manage to get frt wheel back and can't say enough about framestraight..com. That frt wheel is so straight.!! Doing body work hope to be painted in a 3 weeks.Bike painted starting to get the lil things taken care of found an oil cooler off a newer bike but bigger. D&G chassis made a sprocket for me ,which i highly recemend, nice people easy to deal with.. Well have to go back thru motorcycle and make sure lil things r done update later.
old school w/ new look
02gsxr 1000 front forks w/6 piston calipers
06 gxsr 750 rear suspension
6 speed trans out of gpz550
Reinforced frame
Reinforced frame
Last edit: 14 May 2012 12:57 by RTGPZ.
- Mcdroid
- Gone Kwackers
Re: retro gpz 750
13 Nov 2011 18:05
I liking it!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- camaroguy
Re: retro gpz 750
14 Nov 2011 08:40
The bike is looking good. now how bout a couple pics of the whole bike.
- RTGPZ
Re: retro gpz 750
14 Nov 2011 08:46
my profile pic is all i have until its closer to being finished
Reinforced frame
Reinforced frame
Re: retro gpz 750
14 Nov 2011 14:17
Buckin A Fubba!!!!!!! :woohoo:
nice work! :evil:
welcome.
we will require more pics!!!!!!!!!!!
keep us posted,
nice work! :evil:
welcome.
keep us posted,
