KZ1000 modern fork swap
- mkz
13 Oct 2011 14:38
I have a '81 Kawasaki KZ1000 looking to do modern fork swap. I have a complete ZX7 front end of a 2002. The tripple trees do not work, is there another tripple I can use with these forks that will bolt on? Any recommendations on what swing arm set up will bolt on to this bike? Thanks.
- mark1122
- Keep twisting it
Re: KZ1000 modern fork swap
13 Oct 2011 16:30
i'm not sure why those tree's would not work? did u try swaping the stem with a kz stem? that is the normal procedure for most modern front end swaps.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mkz
13 Oct 2011 16:55
Found the zx7 stem is to wide and short to work.My buddy has them and says he does not think the kz stem will press into the zx one.But he just eyeballin it i think.Also which rear swingarm is the easiest swap to do?
- Boostable
13 Oct 2011 17:13
The ZX Trips will work, you just need to swap the stems and make a bushing (possibly out of the ZX stem). Looks in the projects sections, many people have dont just that.
Lots of options on the swing arm. Pick your poison. NONE are direct bolt ins and will require a bit of fab work. Want dual shock, or mono? Square Tube or something modern? Short list of things you could look at. ZX9(early), 636, GSXR 100, 750 and 600. GS1000E I believe as well.. and thats a very short list.
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
- Boostable
13 Oct 2011 17:17
Start here...
kzrider.com/filebase/doc_download/430-ol...swing-arm-conversion
kzrider.com/filebase/doc_download/431-ol...front-end-conversion
Great start...
Great start...
~Jack
The following user(s) said Thank You: bluezbike
- mkz
13 Oct 2011 17:53
I have a complete rear end setup off a 94-97 ZX 9.The swingarm is to wide,whats the best way to go about this problem?
13 Oct 2011 17:57
send it to me and i can mill the pivot tube down to the right width and build some bushings to take up the slack between the kz swingarm bolt and the zx bushing.
if that would help you out shoot me a pm.
- mkz
- Derigo
- badrhino
17 Oct 2011 01:21
Derigo nice bike. Do you have a build thread on it?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- mark1122
- Keep twisting it
18 Oct 2011 17:25531blackbanshee wrote: send it to me and i can mill the pivot tube down to the right width and build some bushings to take up the slack between the kz swingarm bolt and the zx bushing.
Follow LEON , my son.
Do not be afraid, of the dark side.
as he is our jeti master kz fabricator.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- porchev914
19 Oct 2011 01:43mark1122 wrote:531blackbanshee wrote: send it to me and i can mill the pivot tube down to the right width and build some bushings to take up the slack between the kz swingarm bolt and the zx bushing.
X2! Leon can do just about anything you need
FRANKEN Z!
