GPz750 help?
- Philsbike
GPz750 help?
07 Oct 2011 11:57
Ok all, I have fitted the back end into the bike, had to make up spacers but no real problem. I am however struggling with the front end. I cannot find out why my front wont go, I have got a ZXR400L front wheel which will not bolt up into my front end, I am trying to find out if the 400H wheel is narrower and if there is a narrower speedo drive that will fit.
Any help would be great....
Attachment IMG_0588.JPG not found
Attachment IMG_0592.JPG not found
- gengomerpyle
Re: GPz750 help?
07 Oct 2011 20:16
what do you have inside the tail piece?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- Philsbike
Re: GPz750 help?
08 Oct 2011 05:48
Its the ECU, the bike has a later GPZ Turbo engine, hence me wanting better brakes!
- 0Z.Z1R Mk2
Re: GPz750 help?
08 Oct 2011 06:31
Wont bolt up to where Phil?
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
- Philsbike
Re: GPz750 help?
08 Oct 2011 06:45
I cannot line up the front wheel, the speedo drive unit is too wide, I need around 4mm off the drive, as I said, I'm sure this is something that has been done before.
