Doctorot's '78 KZ1000 build
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: DoctoRot's '78 KZ1000 build
17 Mar 2015 05:47
#664704
glad you got the parts.
i would use the thinnest ones i had to start with just so you can get some measurements and get a reference to start from.
  • DoctoRot
  • DoctoRot's Avatar Topic Author
22 Mar 2015 16:35 - 22 Mar 2015 16:41
#665259
Another small item off the check list. I shaved the stock fender mounts and made a bracket off the caliper bracket. very pleased with how it turned out. Just need some cool fasteners to finish the front end off. I was thinking about 12 point flange bolts for the fork/caliper bracket. Maybe some button or allen head screws for the caliper and disk? Any suggestions on some trick hardware?
Last edit: 22 Mar 2015 16:41 by DoctoRot.
  • 80B4
  • 80B4's Avatar
Re: Doctorot's '78 KZ1000 build
22 Mar 2015 18:24
#665288
Vic,
Yamaha uses some very nice gun drilled bolts to mount the front calipers on the first generation R1. I've used them for years and they are cheep. I also use a lot of A4 grade stainless allen bolts from McMaster. If I install them in a high viability area I true up the OD on my lathe and cut the heads to a 10 degree taper and polish them with a scotch-brite wheel, they look a lot like titanium when done.
Nice work so far! Are those EBC front rotors?
1980B4 1000
1978 Z1R
1978 B3 750
  • DoctoRot
22 Mar 2015 22:23
#665317
80B4 wrote: Vic,
That is what i'm talking about, thanks! Those bolts are sweet, looks like Yamaha used them all the way to 2013 on many bike models, so only $2.54 brand new. They appear to be 10mm bolts, but I cant seem to find what pitch they are. Its japanese so I assume 1.25?
The rotors are custom ISR, to get enough offset to use the twin pot Grimecas on a spoked wheel. They do look remarkably similar to the EBC ones.
  • 80B4
  • 80B4's Avatar
26 Mar 2015 17:24
#665342
Yes, the Yamaha caliper bolts are 10mm X 1.25. ISR parts are very nice, their hand controls are on my wish list!
1980B4 1000
1978 Z1R
1978 B3 750
  • DoctoRot
27 Mar 2015 20:23
#665472
Thanks again 80B4 for the tip on those bolts. they are perfect. i like how they match the anti rattle bobbins in the disk. I also got some there stuff for the forks as these are only 30mm long. I blew WAY too much money on fasteners. Thank god i don't have kids; i would be a terrible father.
"sorry kiddo you're gonna have to wear those shoes for another 6 months. I don't care the sole fell off one and your toes are poking out, daddy needs to buy overpriced hardware for his toy."
  • 531blackbanshee
  • Vendor
  • Vendor
30 Mar 2015 06:54
#665769
very nice!
  • Arnold
  • Arnold's Avatar
03 Apr 2015 14:39
#666436
Bloody hell your good....very impressive range of skills ! :woohoo:
  • DoctoRot
03 Apr 2015 17:43 - 03 Apr 2015 17:44
#666453
Thanks guys. I should have a solid update soon, I have been waiting on parts and dealing with painting. I was trying to use POR-15 Hardnose paint on my frame, and i just couldn't get a satisfactory finish with it even after several attempts and contacting their tech support. Its very finicky, although it seems like really tough, good paint. I dropped my frame off for powder coating and should be getting it back monday, then final assembly can begin!!! :woohoo:
Last edit: 03 Apr 2015 17:44 by DoctoRot.
  • 80B4
  • 80B4's Avatar
03 Apr 2015 18:51
#666463
Vic,
Those 10mm bolts look very good in that location! The union bolts that Yamaha uses on early R1 brake lines are interesting too. They are allen bolts instead of a normal hex head.
1980B4 1000
1978 Z1R
1978 B3 750
  • DoctoRot
08 May 2015 17:45 - 08 May 2015 18:01
#671181
I was hoping to have the engine in the frame for this update, but... I was degreeing the cams when i discovered the cam chain was too short, did some research and found that the MKII motor uses a 124 link chain. I bought the wrong one with 122 link, probably back when i thought i had a 78 motor. This means total teardown to install the correct chain. :( Sometimes i wonder if there is something or somebody out there secretly conspiring to keep me from finishing this project. But seeing as this is my fourth time taking it apart/ putting it back together i think i will be able to do it in an afternoon once i have the cam chain.
Some good news; I ended up powder coating the frame gloss black, and it was probably one of the smarter decisions i have made so far. White was just too overpowering for some of the other cool stuff going on, also a nightmare to keep clean. I also did my first bit of TIG welding on this and finished the foot for the kick stand. I still need to find a stainless ball bearing to weld on the end like the stock kickstand.
Last edit: 08 May 2015 18:01 by DoctoRot.
  • mopguy
  • mopguy's Avatar
08 May 2015 19:22
#671188
Looking very good! so far, take your time and finish it the way you like it, don't rush it, time is all we have in this world.
