KZ1000 Bobber for a college student
  • Motor Head
  • Motor Head's Avatar
Re: KZ1000 Bobber for a college student
11 Dec 2011 01:19
#492610
not a bad piece of ingenuity, but I fear the small rear tank mount that you've Hung off of won't hold up. Better re-do the mount there, something able to take the leverage and weight.
  • kcornell6
  • kcornell6's Avatar Topic Author
11 Dec 2011 06:09
#492624
Motor Head wrote: not a bad piece of ingenuity, but I fear the small rear tank mount that you've Hung off of won't hold up. Better re-do the mount there, something able to take the leverage and weight.
There's actually a second larger bolt under the tank where you can't see it. The tank bolt really just prevents lateral movement rather then the leverage part.
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
  • kcornell6
29 Jan 2012 16:53
#500688
Hey all,
Been a long time since I've updated this thread. Been working on electronics alot, re-fiting that PVC airbox, re-wiring the controls, and boltin on some signals n lights. Got the new pipes welded on there. Had a problem with firing for a while but got that worked out. Was recieving too much air. So still works on original carb settings after putting a washer in the muffler to create some back pressure. Really startin to bring it home now in the last stretch of the project.
Really hated all that non-sense police crap... Threw a 2nd kill switch which goes in the gusseting on left side near where the tank bolts up. Tank hides it nicely, but still accessible.
Signals tucked in under leaf spring seat.
Just shot it with some black really quick. Will be doing a more "official" job later down the road.
More pics to come later.
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
  • kcornell6
14 Aug 2012 01:43
#542464
I've been away from bein able to make any serious progress on this machine. Finally something "worthy" posting. She's not 100% yet, and I'll always find reasons to work on her. But for now, it's only a day or two away from being road ready.
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
14 Aug 2012 11:24
#542524
nice and clean.
looks good.
i gotta tell ya tho.
i have seen struts that were thicker than yours fold up and bend into the wheel and clean out all the spokes,which dropped the bike down and drug the frame.it was at around 40 mph or so so the guy rode it out and didn't wreck.
every bump is trying to bend your struts in half :whistle: .
some round tubing will resist the bending forces better than solid stock.
  • kcornell6
14 Aug 2012 20:59
#542645
Thanks Leon. It's something I kind of always looked at over n over again. I think I may take apart the old shocks and use the innards for the strut.
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
  • 531blackbanshee
  • Vendor
  • Vendor
15 Aug 2012 10:41
#542758
i have a set of chromoly tube struts that i have used on my z1r they are 11 1/2 inches long tho.
i could knock you up set using chromo tube and machined ends whatever length you wanted.
i just hate to see something go wrong.
lemme know if i can help you.
  • BRABBIT04161991
  • BRABBIT04161991's Avatar
19 Oct 2012 22:27
#554777
Anyone know what size PVC he used?? I wanna kinda do the same thing on mine except have the air filters pointing forward like some other v twins
  • SlowRoad
  • SlowRoad's Avatar
23 Oct 2012 17:39
#555412
BRABBIT04161991 wrote: Anyone know what size PVC he used?? I wanna kinda do the same thing on mine except have the air filters pointing forward like some other v twins
I'll bet it's 1 1/2" cause that's what I just used to make mine...
This is my breather cover. I tried the front facing filter, but it wasn't comfortable and in the way so I came up with this. It's now flat black, but this is in primer...
1981 KZ1100-A1 Shaft
1997 Valkyrie GL1500
1998 KLR650
1978 KZ750-B Twin
  • BRABBIT04161991
23 Oct 2012 23:11
#555501
That's beast. Now I'm going to do exactly what you did on your except i'm going to extend the air filter forward about another 6 or 8 inches forward. Did you have to up your jet sizes at all??
  • SlowRoad
  • SlowRoad's Avatar
24 Oct 2012 08:53
#555539
I had already upped the jet size with a stage 3 kit. I had individual cone filters on it before doing this. I think I used the .155 mains. The kit came with .155 and .160. The .160 were a little too much so I went back with the .155. It still needs some tuning, but it runs better with this setup than the cone filters.
1998 KLR650
1978 KZ750-B Twin
  • Nelson
  • Nelson's Avatar
25 Oct 2012 00:48
#555668
Holy cra...! Those PVC intakes are sumthin' else! I like the idea but, I have to be a bit skeptical of how well it will run... All 4 carbs sucking thru 1 tube the same size? Or 2 on the other design. Seems likely to produce good low rpm torque and starve for air at high rpm or wide open throttle.. just guessing. Interested to hear more.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
