kcornell6 wrote: After playing with that scrap PVC I found myself at Lowes today. Spent $15 on the piping for this new airbox type of thing. Something I came across, even though it may not be necessary to install, was a valve. So at the opening, just put another pipe that has an adjustable valve. This will change the amount of air coming through is there's too much because of the new pods. Might not look all that great, but would sure get the job done without adjusting carbs. Could adjust the amount of air coming through if you go from a high elevation to low also if your carbs are set up for higher areas.
No cutting needed. Fit all together like it was made for the carbs
V/R
Kev
Chaotic Reason wrote: Or is this it?
Attachment photobucket-2402-1320195275200_2011-11-01.jpg not found
kcornell6 wrote: .... Might go look at the local salvage yard for 250 rebel shocks...
Kev
650ed wrote:kcornell6 wrote: .... Might go look at the local salvage yard for 250 rebel shocks...
Kev
That will be asking a lot from those shocks. A 250 Rebel weighs 300 lbs.; a KZP weighs 600 lbs. So even if you can trim 100 lbs from the KZP the shocks will be undersized for the job. Ed
