KZ1000 Bobber for a college student
  • kcornell6
  • kcornell6's Avatar Topic Author
Re: KZ1000 Bobber for a college student
31 Oct 2011 14:36
#486284
Hey all,
Trying to work on the project where I can.
Got the frame mocked back up for welding. Not going to post pics till that's done though.
Since I did this with my 81 GS850, I thought I'd try it again. I want to replace the stock mufflers, cause they are just not bobber like whatsoever. Went around to a few dealership to see if they had any throw away mufflers laying around the shop. Was striking out for a little, but patience helps out. Came across this small chopper shop down the street, Iron Horse Caroe who really helped me out. They handed me over these bad boys...for FREE. Their in great shape, literally nothing wrong with them. Great people there.
When I pull the clutch, it's kind of sloppy. Lever pulls fine, but doesn't have any tension to bring it back. Have tried adjusting the cable but didn't help out really. Pulled the cover off to see what's going on. Maybe this spring is worn down?? Any ideas?
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
  • Chaotic Reason
  • Chaotic Reason's Avatar
31 Oct 2011 14:53
#486289
I don't know about the spring, but you definitely want to lube your cables. Great find on the slip-ons.
Michael
1980 KZ1000 shaft drive
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
31 Oct 2011 15:26 - 31 Oct 2011 15:27
#486303
your spring is either good or broken.(i've never encountered one of these springs that has just weakend)
we can see it is not broken, :) (they don't call me holmes for nuthin :silly: )
so i would suggest taking your clutch pusher out of your cover and washing it out with some solvent.then give it a re-grease and as chaotic mentioned lube your cables.
something is dragging (capt. obvious again :whistle: )and it is a simple setup.
soo cable,clutch pusher,or pivot,unless you have broken pressure plate springs under the clutch cover on the other side.
these are great for lubing cables easy and fairly clean.worth having for sure.
Last edit: 31 Oct 2011 15:27 by 531blackbanshee.
31 Oct 2011 15:42 - 31 Oct 2011 15:49
#486306
kcornell6 wrote: ... When I pull the clutch, it's kind of sloppy. Lever pulls fine, but doesn't have any tension to bring it back. Have tried adjusting the cable but didn't help out really. Pulled the cover off to see what's going on. Maybe this spring is worn down?? Any ideas?
Supposed to be a screw and locknut that are used to adjust the clutch push-rod. Are they missing? Is the push-rod missing?
It's not the light duty spring, imo, as that spring provides minimal tension needed to hold the clutch lever into its perch so the lever won't vibrate due to the slight required slack in the cable.
Good Fortune! :)
Last edit: 31 Oct 2011 15:49 by Patton.
  • kcornell6
31 Oct 2011 15:47
#486308
Thanks for the tips gents. Will be looking into it.
The locknut and screw are there n working fine. Hopefully I don't need to look into the clutch bucket.
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
31 Oct 2011 15:55
#486310
kcornell6 wrote: ... The locknut and screw are there n working fine....
Clutch push rod adjustment is sometimes incorrectly performed by first turning the adjustment screw the wrong way.
Ball and ramp style -- first turn screw counter-clockwise until it stops, then turn clock-wise 1/2 turn, then tighten the lock nut.
Earlier model with screw type adjuster is turned the opposite way.
Good Fortune! :)
  • kcornell6
01 Nov 2011 22:06
#486579
Hey guys,
Got some work done today which felt so good. Love getting the hands dirty more then once a week.
Figured out my clutch lever problem. The cable itself was pretty clean, but cleaned it anyways. In the previous pic pictured with the spring, I cleaned that all up REALLY well. My uncle has a special kerosene cleaning sink for parts like this. Wish I took a pic of it before I got new grease in there. What it came down to was a little time and patience getting all the adjustments correct in 3 different areas. Thanks to Patton for the advice, helped much. So all is well there now.
In the following pic, you can kinda see how the frame was rewelded at a different angle. Many probably wont be able to tell a difference, but it's ok cause I do and this baby is mine. =]
And can anyone spot the turn signals I mounted????
I'm not sure how I feel about this fender in this position with the flare at the end. I have another fender on my GS pictured in the 1st post which could fit and doesn't have this flare. Let me know your opinions cause I'm on the edge about it. Color wont make a difference since the'll get painted.
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
01 Nov 2011 22:32
#486594
Fender looks good. I actually like the flare. Almost makes it look like a fin.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • ramtough_63
  • ramtough_63's Avatar
01 Nov 2011 22:38
#486597
kcornell6 wrote: After playing with that scrap PVC I found myself at Lowes today. Spent $15 on the piping for this new airbox type of thing. Something I came across, even though it may not be necessary to install, was a valve. So at the opening, just put another pipe that has an adjustable valve. This will change the amount of air coming through is there's too much because of the new pods. Might not look all that great, but would sure get the job done without adjusting carbs. Could adjust the amount of air coming through if you go from a high elevation to low also if your carbs are set up for higher areas.
No cutting needed. Fit all together like it was made for the carbs
V/R
Kev
Love The PVC used it as an intake for a single carb conversion on my Goldwing Still going strong after 2 seasons.
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
01 Nov 2011 22:41
#486598
Is that it? Did I win? Is there a prize? LOL! :woohoo:
BTW, I like the flipped clubman handlebars...looks pretty cool :)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
  • Chaotic Reason
01 Nov 2011 23:55
#486624
This is my guess...
Attachment photobucket-2402-1320195275200.jpg not found
Michael
  • Chaotic Reason
02 Nov 2011 00:00
#486627
Or is this it?
Attachment photobucket-2402-1320195275200_2011-11-01.jpg not found
Michael
