1982 KZ750 E3 Complete Wiring Overhaul
  • Motor Head
  • Motor Head's Avatar
Re: 1982 KZ750 E3 Complete Wiring Overhaul
04 Oct 2011 00:44
#481278
Is that an aftermarket Regulator/ Rectifier? Black wire would be ground then, and yes Must be connected to a good clean ground on the frame.
Solenoid connections, it is just an electromagnet, the two small wires just need one connection each, power through the Start button and ground to energize its coil.
The following user(s) said Thank You: clutch
  • clutch
  • clutch's Avatar Topic Author
  • I wish I had a tad more patience to do it better!
04 Oct 2011 00:49
#481279
Motor Head wrote: Is that an aftermarket Regulator/ Rectifier? Black wire would be ground then, and yes Must be connected to a good clean ground on the frame.
It's a Rick's reg/rect (I think...definitely aftermarket). Weird thing is, that it worked the way I had it hooked up when it was stock. If grounding that reg/rect is the right thing to do, then no worries...I can do that! Thanks for the reply. I've been trying to figure out what I needed to do here for a couple days (didn't want to damage anything). Now I can button it all up and start on some fresh paint...then my '66 Samurai project finally begins (2 years after buying the bike LOL)! :woohoo:
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • Motor Head
04 Oct 2011 00:55
#481280
So it that a 6 wire R/R with the brown wire? if so then the Brown is the voltage sense wire, it needs to be Switched to as close to Battery voltage as possible. If it sees lower than battery voltage it will make up the difference on output. Possibly overcharging the battery.
If it is 5 wire then it will not have a Brown, it will do the voltage sensing on the White/ Red output wire.
  • clutch
04 Oct 2011 00:58 - 04 Oct 2011 00:58
#481281
Motor Head wrote: So it that a 6 wire R/R with the brown wire? if so then the Brown is the voltage sense wire, it needs to be Switched to as close to Battery voltage as possible. If it sees lower than battery voltage it will make up the difference on output. Possibly overcharging the battery.
6 wire. I'm hooking up the brown wire to the "always hot" (but fused) wire that powers the clock on my Acewell. I just haven't gotten quite that far yet into the project. Shouldn't take me long to finish it all up though :)
Wish List:
Last edit: 04 Oct 2011 00:58 by clutch. Reason: chubby-finger typo fixin'
  • Motor Head
04 Oct 2011 00:59
#481282
6 wire, Brown must be switched, or battery will drain/ discharge.
  • clutch
04 Oct 2011 01:00
#481283
OH!!!!! That shouldn't be on a always hot wire then...hmmm...glad I didn't get that far yet...easy fix :)
Wish List:
  • Motor Head
04 Oct 2011 01:04
#481285
clutch wrote: OH!!!!! That shouldn't be on a always hot wire then...hmmm...glad I didn't get that far yet...easy fix :)
Yes sir. :)
  • clutch
04 Oct 2011 01:04
#481286
Ahh...looked at the wiring diagram wrong. I thought that brown wire was hooked to one of the aux power supplies...but it's hooked into the power feed for the brake light. Good save sir :)
Wish List:
  • clutch
04 Oct 2011 01:19
#481287
Looking back at my pics, I realized that that black wire was connected to a yellow/black ground wire. I thought it was connected straight to the red/yellow wire (ground) from the solenoid...silly me. I feel better now that I know what I did wrong :silly:
Wish List:
  • clutch
05 Oct 2011 02:16 - 05 Oct 2011 02:16
#481434
Alright, so now that I have the solenoid/regulator mistake worked out, I turned towards lighting. I wired up the headlight (high and low), connected the high beam indicator wire and tested it. As a note to those with aftermarket headlight brackets like me, I had to flip them so they were angled up to have enough movement to properly adjust the headlight with the clipons. It was hitting the cross piece the other way.
I also added an extra indicator light, which will serve as my low fuel warning light. I was going to remove the sensor, but decided to keep it since it can be useful. The only place I could figure out to mount this and still have the bike look fairly clean, was in the top of the headlight bucket.
As a side note, I was playing around with my dremel earlier using pieces from the polishing kit I have for it. I used it a bit on one of the fork lowers to try it out. It looks a lot better in person than in the pic, but I'm open to suggestions/advice as I don't really have any experience polishing metal.
All that is left is the tail light, brake light, oil press wire, neutral wire, and the turn signals (which I am not wiring now because I need new ones, and MD says I don't have to have them). If I don't finish this up tomorrow, it will be done Thursday :)
Wish List:
Last edit: 05 Oct 2011 02:16 by clutch.
  • clutch
06 Oct 2011 02:47 - 06 Oct 2011 02:48
#481637
Alright...got everything wired except for the horn, low fuel light, and the taillight. The brake switches are wired so that when the brake light comes on, so does the hazard indicator light on my acewell. I did this because I won't be running hazards when I get some new turn signals and install them. After everything is wired, there are a couple things I will need to trim because I left too much slack, and then I will button it up. The very LAST thing I will wire is the low fuel light. The wires are run, but they just need to be connected. No pics this time, but when everything is done, I will post some of the finished project (probably tomorrow)! :woohoo:
Wish List:
Last edit: 06 Oct 2011 02:48 by clutch.
  • clutch
06 Oct 2011 19:58
#481768
I spent almost all day today cleaning up the garage, so I didn't get much done on the bike. I still need to mount the ignition switch, wire the horn, wire the taillight, and cleanup the wiring with cable ties/wire loom. I did a quick mockup for the cafe tail. I think I am going to take off 6 inches or so off the front, so it won't stick out quite so far. Once I have that figured out, I can finish wiring the taillight. Don't mind the red paint on part of the tail, I was just trying out some rustoleum to see if I liked it....still undecided...
Also, while I was cleaning up the garage, I found a solution to my missing fork air valve. I'm thinking it's a bit too much, but I do have 4 of them, so I can put the other 2 on the wheels. What do you think? LOL! :woohoo:
So...maybe tomorrow I will get this project done (a week after my initial goal completion day).
Wish List:
