1982 KZ1000 to Fighter..
  • faffi
  • faffi's Avatar
Re: 1982 KZ1000 to Fighter..
04 Feb 2012 16:12
#502020
How long are these forks compared to the typical stock length of our old KZs?
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
  • Boostable
  • Boostable's Avatar Topic Author
05 Feb 2012 10:34
#502195
Much shorter...
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
  • faffi
  • faffi's Avatar
05 Feb 2012 10:58
#502198
In other words you need to either lengthen the forks or make triple clamps that drop way down to compensate for the missing length. If not, you will lose cornering clearance, something that isn't available in abundance even in stock form.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
  • Boostable
05 Feb 2012 12:36
#502219
Sorry for the none technical answer... Lol. You are correct. Between the fork length and smaller wheels, you definitely lose some clearance. Triple clamp is a good way to make it up.
~Jack
  • camaroguy
  • camaroguy's Avatar
05 Feb 2012 18:01
#502268
I know this will throw a wrench in all theories but,I have a 081k gsxr front end on my bike and havent really noticed a issue with either dragging header or pegs and or handling?I am by no means a world class rider but consider myself pretty decent.with the lighter overall weight of the bike, better tires with the modern wheels and, oh boy alot better brakes?
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Feb 2012 18:20 - 05 Feb 2012 18:52
#502273
u can lose a couple inches for the forks then another 1 3/4" for the 17" tire (3 1/2" divide by 2 = 1 3/4")
i chose the go with the longer zx9 forks. then i massaged the top tree to gain an extra 3/4".
Attachment forksfrom3zs.JPG not found
Attachment 03123822_2012-02-05.JPG not found
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 05 Feb 2012 18:52 by mark1122.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Feb 2012 18:26 - 05 Feb 2012 18:48
#502275
i massaged the top tree to gain 3/4" as can be seen hear.
before
Attachment zx9tree1.jpg not found
after
Attachment 96zx9toptree002.jpg not found
then i was able to drop the forks this much
Attachment 96zx9toptree007.jpg not found
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 05 Feb 2012 18:48 by mark1122.
  • faffi
  • faffi's Avatar
05 Feb 2012 19:01 - 05 Feb 2012 19:03
#502284
camaroguy wrote: I know this will throw a wrench in all theories but,I have a 081k gsxr front end on my bike and havent really noticed a issue with either dragging header or pegs and or handling?I am by no means a world class rider but consider myself pretty decent.with the lighter overall weight of the bike, better tires with the modern wheels and, oh boy alot better brakes?
Modern sportbikes will be able to run their tyres not only to the point where there are no chicken strips, but quite a bit beyond that. If you, running radials, scrape things before using up all of the rear tyre and have more than 1/4 in of chicken strip remaining on the edges of the front, I will say that you have a clearance issue that will be noticed during every halfway spirited ride on a winding road. The wider the chicken strips, the greater the clearance problem, of course.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
Last edit: 05 Feb 2012 19:03 by faffi.
  • Boostable
11 Feb 2012 11:00
#503317
As I was waiting for my pant to dry (another thread) on my 900 I got to work on some new rear set mounts for the 1000. I originally had some T-Nuts welded to the frame, but just wasn't happy with setup, and I wanted the sets a little lower and possibly some adjustablity.
Here is what I came up with . They are not finished yet. I need to clean them up and figure out if I want to put another mounting hole in the end so it would have two settings one low and one a little higher with more angle. I think I might wait to get the engine set before I make that decision. Add some spacers to support the bottom and get some proper bolts to match everything.
Other then that, they are a little thin so I might remake them with some 1/4 that I have. If I do that I may need to find some thinner swingarm nuts.
~Jack
  • Julian@MotoCARR
  • Julian@MotoCARR's Avatar
  • Automotive Afficianado
12 Feb 2012 02:39
#503435
Great build, subscribed!
Humans are smart
People are stupid
  • Boostable
13 Feb 2012 23:39 - 13 Feb 2012 23:40
#503864
Making progress boys!!!
Covers are just stuck on for aesthetic purposes, gonna work on getting them finished this week and get this baby set in the frame.
Yea baby!!!
~Jack
Last edit: 13 Feb 2012 23:40 by Boostable.
  • ramtough_63
  • ramtough_63's Avatar
13 Feb 2012 23:59
#503872
Thats F@%#in gorgeous!
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
