81 GPZ 1100 efi fuel tank ????
- busy1
10 Sep 2011 15:22
I have an 81 GPZ 1100 efi project that someone has converted to carbs. The tank is pretty beat. I am going to a swap meet this weekend looking for a tank and am wondering what has to be done to the efi tanks to make them work with carbs? Is there a tank that will just replace it with no mods?
Thanks
Thanks
- Mcdroid
- Gone Kwackers
Re: 81 GPZ 1100 efi fuel tank ????
10 Sep 2011 16:36
To convert your existing tank to use with carbs, you must move the petcock about 100mm (give or take) towards the front of the tank. You must also cap off the pressure relief valve opening.
OR...find a 1982 GPz1100 tank and merely cap off the pressure relief valve opening.
OR...find a 1982/1983 KZ1000 ELR tank.
Good luck on finding tanks...they are all becoming very very scarce.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- busy1
10 Sep 2011 16:49
Thanks, will look tomorrow at Rice-O-Rama.
- camaroguy
10 Sep 2011 16:56
On my 81 gpz i cut all the stuff off the bottom of the tank and moved my petcock rearward by about 2 inches.I used a hole saw over the threaded part of tank and then had a friend tig all holes and petcock.for venting I put a theaded hole in the top in front of cap and vented with a hose. same as the s1 model.I use a dual feed pingel with 34mm mikuni flatslides. works pretty good.if yours is a 81 you will need to plug the injector holes on intake ports or get a new head.
