MkII instrument pods on ST?
- fxdl2051
28 Aug 2011 06:09
I swore to myself I'd keep it stock, I lied. Anyone know if the instrument cluster off a KZ1000 MkII will fit a KZ 1000 ST? I think they look way better, especially with chrome end caps on the instrument pods. Just wondering if this is easily doable?
Thanks all,
Ken
Thanks all,
Ken
- trianglelaguna
Re: MkII instrument pods on ST?
28 Aug 2011 10:08
MKII were black and pretty close to the st i thought...some members have both bikes....i think they can be used on either ...i put the shiny buckets on mine from z1 ent.
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- etbike3135
28 Aug 2011 14:49
Its been a few years since I had a shaft but I dont think the gauge bracket is the same. THe MKII has a common KZ style gauge bracket and the shaft is unique to itself I believe. You cant just change out the top triple tree either becasue the shaft has 40mm forks and the MKII 36mm and I believe the offset is different also.
1973 Kawasaki Z1
18 years in dragbikes
- KZ_Rage
- Kentucky Bourbon Barrel Ale
30 Aug 2011 12:20 - 30 Aug 2011 12:21
It's a no can do, even the E1 and E2 are different just a bit for the added dampers on the indicator box on the E2
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
Last edit: 30 Aug 2011 12:21 by KZ_Rage.
- trianglelaguna
30 Aug 2011 18:56 - 30 Aug 2011 18:57
but all you mentioned unless im wrong , is the shiny look..order new instrument cans from Jeff at Z1 ent..cheap one screw to install and it will dress the front up nice...
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
Last edit: 30 Aug 2011 18:57 by trianglelaguna.
- KZ_Rage
30 Aug 2011 22:39
If it is the bottoms he wants then it's still a no go...
from Z1 - "Fits Kawasaki Early KZ650 (77-80), KZ750 (76-79), KZ900/Z1/KZ1000 (73-80), Does NOT fit KZ1000-E (shaft) models with flat-bottomed meters."
Tops can be covered to get the chrome look though.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
- fxdl2051
03 Sep 2011 02:10
Bummer, I really like the look of the MKII instrument cluster, but I guess some add on chrome dress rings will have to do.
I was hopping someone had found a work around or had made a bracket that would work for the setup.
Thanks all,
Ken
Thanks all,
Ken
