Trash Can Dave 650
  • arldavey
  • arldavey's Avatar Topic Author
Trash Can Dave 650
06 Jul 2011 12:57 - 06 Jul 2011 12:57
#461307
Last edit: 06 Jul 2011 12:57 by arldavey.
Re: Trash Can Dave 650
06 Jul 2011 13:10
#461310
Man, that engine was bored all the way out :woohoo:
  • arldavey
06 Jul 2011 13:18
#461312
and then someone pee peed in it,
  • arldavey
06 Jul 2011 20:22 - 06 Jul 2011 20:23
#461414
and cracked stuff for recycle
Last edit: 06 Jul 2011 20:23 by arldavey.
  • martin_csr
  • martin_csr's Avatar
Re: -
06 Jul 2011 21:26 - 15 Feb 2013 10:48
#461435
Last edit: 15 Feb 2013 10:48 by martin_csr.
06 Jul 2011 22:10
#461444
The other good news is the parts include an airbox. ;)
  • arldavey
13 Jul 2011 20:43
#462714
  • arldavey
13 Jul 2011 20:44
#462715
crud, that last one was sideways.
  • arldavey
19 Jul 2011 17:01
#463792
Question if 3 of the exhaust valves were clapped shut and one was hung open does that suggest I have to open up the head?
  • testarossa
  • testarossa's Avatar
19 Jul 2011 17:51
#463801
If the camshaft is not what is holding it open, then yes. You have a bent valve.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • hocbj23
  • hocbj23's Avatar
19 Jul 2011 18:32
#463813
The other good news is that mine looked worse than that and it only took me 2 years to get it together and running. Bon Appetite.BJ
  • arldavey
25 Jul 2011 09:46
#464757
turns out I hadn't rotated the crank, valve closed up.Now the real puzzler, I think I have a 78-79 wiring harness and a 77 motor. The stator is different. Can the regulator-rectifier work with the old stator or do i swap it out with the one from the pee motor? the cover on the 77 looks better. - thanks.
