Compatibility Guidance
  • catseye
  • catseye's Avatar Topic Author
12 May 2011 09:03
#450463
Is there a source that can tell me what range of years I can look at to find parts that will work on my 81 750 LTD? I found this 82 750H and thought there might be a bunch of parts I could use:
Thanks in advance...
1982 KZ750LTD
1976 BMW R90/6
1982 Honda CBX
  • Motor Head
  • Motor Head's Avatar
Re: Compatibility Guidance
12 May 2011 09:35
#450469
Start here: www.kawasaki.com/DefaultFrame.aspx?strCo.../VICHOOSEVEHICLE.ASP
And then get into the parts diagram for the model, look up the part, then see the little yellow ? and click, there is also a S which is for superseded parts.
Member Patton has a tutorial on the process, he will most likely post the info or link to that thread.
The following user(s) said Thank You: catseye
  • catseye
12 May 2011 11:40 - 12 May 2011 11:45
#450482
hmmm... when I plug in the year, all I seem to get is
There are no Models found with your selection, please try again
no matter how broad I make the criteria.....
EDIT:
I got the right model by selecting it from the year, but there is no parts diagram page page for it.....
1982 KZ750LTD
1976 BMW R90/6
1982 Honda CBX
Last edit: 12 May 2011 11:45 by catseye.
  • Motor Head
12 May 2011 11:50
#450484
Try this: www.kawasaki.com/DefaultFrame.aspx?strCo...81%26SHOWVEHTABS%3d1
And reopen the parts diagram, not sure if I picked the right model you wanted.
  • martin_csr
  • martin_csr's Avatar
Re: -
12 May 2011 12:07 - 14 Feb 2013 11:06
#450487
Last edit: 14 Feb 2013 11:06 by martin_csr.
  • catseye
12 May 2011 19:11
#450535
got home and pulled it up on my computer. Works great. Thanks for all of your help, guys. I picked the carbs, just for grins, and noticed the carbs for a 80-83 750H are the same as a 80-81 750E, but not 82-83... Any idea as to what the difference might be?
1982 KZ750LTD
1976 BMW R90/6
1982 Honda CBX
