More than I planned, More than I hoped for....
  • testarossa
  • testarossa's Avatar
Re: More than I planned, More than I hoped for....
23 Apr 2011 04:18
#446468
TorreyJ wrote: I've thought of cutting off the back. Plastic welding? you mean melting? I can figerglass so anything is possible. any change of a photoshop drawing of what you mean?
Exactly, you can weld plastic pieces together with heat. I have used a soldering iron to weld plastic parts together. Your tail piece is made from ABS if it's a factory Kawasaki part. ABS responds well to this technique. Here are some shots of my repair to my KZ1000 tail for example. I suggest you google "plastic welding" for further research.
Attachment P1000870.JPG not found
Attachment P1000874.JPG not found
Attachment P1000876.JPG not found
Attachment P1000877.JPG not found
Attachment P1000879.JPG not found
Attachment P1000878.JPG not found
Attachment P1000881.JPG not found
Attachment P1000921.JPG not found
Attachment P1010060.JPG not found
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • lemo32
  • lemo32's Avatar
  • The Price of Cool aint cheap
23 Apr 2011 10:12
#446487
I think the best thing would be to throw it in the trash, it doesnt work with the thirty yr old frame. :sick:
1979 kz 1000 06 katana 750
  • red78ta
  • red78ta's Avatar
24 Apr 2011 09:32
#446677
Yea I think you are going to have to modify that tail section and maybe raise the tank some to make it flow right. Look up that plastic welding technique and sketch out some ideas to make the tail smaller. In the end its your bike so it needs to look right to you, i think you're doing great so far, keep after it!
1979 KZ650C3 (project snow rescue)
1997 Nighthawk 750
Cape Cod, Mass
  • TorreyJ
  • TorreyJ's Avatar Topic Author
09 May 2011 22:30
#449952
Just a quick update on the . It now runs! WOO HOO! seriously, crazy ordeal but glad it is finally running.
who has two thumbs up and loves KZ's?
Attachment two-thumbs-up0.jpg not found
oh wait, not cocaine...lol
anyways. new bars installed, upsidedown and incorrectly. :)
Attachment 29-04-11_2212.jpg not found
my one problem now is that it runs and has good throttle response and all that jazz but here is something weird... sometimes when i get it to idle well, and throttle it up it wants to stay throttled up and rev instead of returning to idle. does that make sense? I know i have petcock issues and i need to set my float bowls but it seems like a strange problem. Any Ideas? Thanks!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
10 May 2011 19:07 - 10 May 2011 19:09
#450152
TorreyJ wrote: Just a quick update on the . It now runs! WOO HOO! seriously, crazy ordeal but glad it is finally running.
that is a common symptom of a lean condition, or sticking cables. have the carbs been cleaned?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 10 May 2011 19:09 by mark1122.
  • TorreyJ
11 May 2011 10:23
#450276
yeah, the carbs have been cleaned and throttle returns the closed position when I let off of it. when I turn the idle screw all the way down it runs fine for a second and then starts to chug for a bit then eventually dies.
Why is it a condition of a lean motor? thanks!
  • flatblack
  • flatblack's Avatar
12 May 2011 02:13
#450445
On mine it was a symptom of a air leak at the rubber manifolds between the carbs and cyl head . Hope this helps.B)
78 KZ1000
Kerker 4 into 1 foam uni filter in stock air box front and rear fender eliminated 95 gpz taillight GS 1100 swingarm works shocks dunlop gt 501s
Lake Stevens WA
Bill
  • TorreyJ
12 May 2011 13:10
#450496
that definitely could be the case. I'll check that out today. thanks.
  • TorreyJ
14 May 2011 04:49
#450878
So here is the current state of the bike
Attachment 12-05-11_2041.jpg not found
Attachment 12-05-11_2112.jpg not found
Not looking too bad, now leaking, yes. I need a new petcock fo sho. I plan on making some sort of sporty fender for the back out of that GIANT ZX6 rear that I have, that will be fun! Oh and I probably need a chain tensioner as well. It still Idles erratically sometimes? whatever, I haven't found any vacuum leaks or sticking throttle, and carbs were just cleaned.
Becky is getting there. I actaully shaved the seat flat today and recovered. I'll have to put up some photos of it now. Thanks for looking!!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
14 May 2011 08:16
#450888
TorreyJ wrote: yeah, the carbs have been cleaned and throttle returns the closed position when I let off of it. when I turn the idle screw all the way down it runs fine for a second and then starts to chug for a bit then eventually dies.
hi revs that come down slowly on there own, is a common symptom of a motor that is running lean.
u may want to consider cleaning the carbs again , if u are sure there are no vacuum leaks. also check for diaphram cracks.
Good luck.
M
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • TorreyJ
22 May 2011 15:31
#452805
UPDATED PICTURES
Attachment 21-05-11_1214.jpg not found
Attachment 21-05-11_1215.jpg not found
Attachment 21-05-11_1216.jpg not found
Attachment 21-05-11_1217.jpg not found
Attachment 21-05-11_1219.jpg not found
Attachment 21-05-11_1220.jpg not found
Attachment 21-05-11_1221.jpg not found
  • cyclhed
  • cyclhed's Avatar
29 May 2011 02:46
#454091
If it's not running right - did you balance the carbs to each other? This will make a huge improvement in the way it runs. You connect a vacuum gauge to each of the carbs and adjust the throttle plates so you have the same vacuum reading on all four. As was already mentioned it will run lean if you have a vacuum leak. Check that all the vacuum lines from the carbs are connected and not leaking. There is one vacuum hose that goes to the petcock and two go into a T and then to the switch valve under the fuel tank. The other carb will have a rubber plug on the vacuum port. There are many other threads on the board that describe how to sync the carburetors. The fuel tank and carbs must be clean and there can be no vacuum leaks though first. Good luck - nice bike.
Past:
1972 175 F7
1974 KZ400
1981 GPZ550
1980 KZ750 LTD
1978 KZ1000
1968 H1500 Mach III
Present:
1982 KZ1000 M2 CSR
