aussie Z1R
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
Re: aussie Z1R
05 Oct 2011 06:23
#481457
Oh, I know the feeling about where the time goes. I opened the shop a couple days ago to do some welding for a guy from work, first thing I see is the bike. Getting the itch badly but going to be at least another 2-3 months before I even have time to even think about it. I do touch base here to see the new ideas floating in, guess I haven't seen Tachrevs shock conversion, going to have to check it out.
Later
Les Holt
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: aussie Z1R
05 Oct 2011 10:07
#481471
as long as you haven't started selling parts of it off,you are just in a lil bit of a "holding pattern" :lol: .
seems either time or money but they are hard to get in the right places at the right time sometimes.
both of ya keep us posted,
  • boyracer
  • boyracer's Avatar Topic Author
Re: aussie Z1R
13 May 2012 10:37
#522022
Evening all. Still looking for carbs.
I came across some Mikuni rs40 flatslide(?) carbs in a z pattern. Too big? I reckon they would swamp a small motor. From memory i had 33mm CR's on the old Hot 1105. Engine now is a stock (?) 1015. Still keen on big turbo, but bargains is bargains...If i could get a 1200ish to run with these carbs that would be a good interim step,no?
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
Re: aussie Z1R
13 May 2012 10:49
#522028
That's awful big carb for a smallish motor. You would be much happier with something around 34's or smaller. Those 40's would be better fitting for a much bigger worked over motor. But as you say "bargains is bargains" so you might turn a buck to go towards what you need. ;)
Les
  • trianglelaguna
  • trianglelaguna's Avatar
Re: aussie Z1R
13 May 2012 11:06
#522034
you could put the carbs it came with on there cheap too...then ride it some
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: aussie Z1R
13 May 2012 19:29
#522121
trianglelaguna wrote: you could put the carbs it came with on there cheap too...then ride it some
X2
40's r too big. 34's would be max.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • boyracer
Re: aussie Z1R
15 May 2012 10:22
#522487
Missing Carbies, keys for seat and tank and 1 x rear shocker when i got it. I've sourced a new fuel cap out of a busted zzr1100 to fit with keys and managed to open seat.
I was attempting to ask how big i should go if i wanted to fit the 40's? Would a 1200/ flowed head do it? or do i have to go larger...1428 / throat the block, etc,etc.
I wouldn't mind getting it rolling again. But if it won't work with just sleeves/pistons.... I'm aware of potential problems in max oversizes and i can do most of my own head work.
I have been out of zeds for over 10 years and nobody locally i know still is. Local 'strip closed years ago. All local efforts to find some 28/29's for stocker or a set of kiehins again have been fruitless. Ebay searching continues....
Alternative is keep it on the bench and build blown motor over next few years.
