1980 kz 1000 shaft tire and rim
- 1980 kz1000e
02 Mar 2011 14:15
i have a 1980 kz 1000 shaft, i am building a cafe racer out of , the factory rear tire is a 130 i would like to put a wider tire on it, are there any other shaft driven bikes with wider tires that i can match up with my shaft drive,and if not whats the widest tire i can get on this rim i plan on doing a few track days with it when i finish the project,thanks for the help
- Nebr_Rex
Re: 1980 kz 1000 shaft tire and rim
02 Mar 2011 18:52
1980 kz1000e wrote:
140 is the widest you can go,because of the swing arm.
The '79/'80 KZ1000st handles different than a chain drive motorcycle.
It will react backwards,rear will raise up on acceleration and squat during braking.
This is because the pinion gear is trying to ride up the other gear in the diff. .
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- gkz1000st
02 Mar 2011 19:31
1979 kz1000st dyna s, wiseco 1075, accel coils, k&n filters,4 into 1 header ,shoei fm5 fairing. Mt.pearl Newfoundland
- Nebr_Rex
02 Mar 2011 21:12
Try that mid corner.:woohoo:
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- kawman14733
03 Mar 2011 05:38
iv seen a vmax rearend on a st,,dont no what was involved to match splines but any machine shop could hook ya up ther
