Stu Pidasole's Build
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
Re: Stu Pidasole's Build
16 Mar 2011 09:04 - 16 Mar 2011 09:06
thanks mark. im ganna knock off the tacks and see where else i can put them. i feel they are too far back also for comfort. ill update when determined.
so mark, did you keep them there and just put up with the discomfort? did you get used to them?
Last edit: 16 Mar 2011 09:06 by Stu Pidasole.
- Stu Pidasole
16 Mar 2011 13:27
i notice when i sit on the bike and hold the bars my foot on the peg, the front of my foot applies pressure to the brake unless i lift my toe. the brake pedal is allready pitcjed down some....should i pitch it down more so my toe is just above the pedal with my heel on the peg?
- mark1122
- Keep twisting it
16 Mar 2011 13:48
Stu Pidasole wrote:
have your foot on the peg as u would while riding.usualy that would put the peg under your arch, and if i have my cowboy boot on my heel can just hang over the peg, and my toe sole will just clear the pedal.
u want to be able to have enough adjustment so u can adjt the pedal for comfort after u are done.
i never did change mine but i should.
your height looks good but i would move it forward,try it under the axle bolt and see if that feel right.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Stu Pidasole
16 Mar 2011 19:35
mark1122 wrote:
im ganna try that. and you mean the swing arm pivot bolt, not the axle bolt right?Stu Pidasole wrote:i notice when i sit on the bike and hold the bars my foot on the peg, the front of my foot applies pressure to the brake unless i lift my toe. the brake pedal is allready pitcjed down some....should i pitch it down more so my toe is just above the pedal with my heel on the peg?
- camaroguy
17 Mar 2011 02:57
On my bike I welded slugs about 3/4 inch round onto the frame above and below the swing arm bolt.that put pegs just about right for me. dont know how to link pics but check my gpz 11oo.slug length can move pegs in or out whre you want tnem.just make sure you check shifter side with the stand in the up position.
- mark1122
- Keep twisting it
17 Mar 2011 04:11
Stu Pidasole wrote:
HA!! :laugh: Ya the swing arm bolt. Sorry.
i guess it would have to be a unicycle to work with the axle bolt.
mark1122 wrote:im ganna try that. and you mean the swing arm pivot bolt, not the axle bolt right?Stu Pidasole wrote:i notice when i sit on the bike and hold the bars my foot on the peg, the front of my foot applies pressure to the brake unless i lift my toe. the brake pedal is allready pitcjed down some....should i pitch it down more so my toe is just above the pedal with my heel on the peg?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Stu Pidasole
17 Mar 2011 04:33
im ganna wait till i have the entire motor bolted in. this way theres no doing shit twice.
17 Mar 2011 10:11
Stu Pidasole wrote:
wow,joe what ?
this does not sound like you :ohmy: .
so what are we going to watch while you are waiting for your engine?
he!! nads hasn't even posted for a couple days :laugh: .
go steal some shopping carts and cut em up and weld em back together so we can have something to watch :silly: .
wow,joe what ?
- Stu Pidasole
17 Mar 2011 15:06
531blackbanshee wrote:
look what i found......:laugh:
Stu Pidasole wrote:im ganna wait till i have the entire motor bolted in. this way theres no doing shit twice.
wow,joe what ?
- Stu Pidasole
17 Mar 2011 16:19
patton, where did the cart with my bike go? that was so awesome.
