Harley rim on a CSR...rear?
  • Genius
  • Genius's Avatar Topic Author
27 Jan 2011 18:47
#426254
I did search without any luck, has anyone put a
Harley rim on like a 1981 KZ1000 CSR
The rim I'd like to use will most likely come off
a 2000+ H-D Nighttrain Soft-Tail 16in
I'm not lookin for a direct bolt-in and I do have
a lathe and mill but I'm no machinist, but I do know a few.
Just wondering how much is involved before I get my hopes up!
I would even consider running the belt if it's possible?
I do know anything is possible, I'd like to keep the stock swing-arm also but open to suggestions.
I'm going through the whole bike and the NightTrain rim
would be perfect for my build!
Thanks!
Gene
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Harley rim on a CSR...rear?
27 Jan 2011 21:47
#426336
is it a wire or disc wheel,how wide is it?
you can normally squeeze a 130/16 in a stock swingarm without too much issue,wider wheels usually require differant swingarm B)
  • Genius
28 Jan 2011 07:33
#426435
It is solid disc, and I need a 150/160 tire...
Sounds like a new swingarm.
I havent even looked at what I got...yet.
I may have a complete Fatboy wheel that I can use
as a guide, pertty sure its the same rim other than
the NightTrain rim is blacked out in the center.
What can I expect to pay for a steel swingarm
Maybe 1 inch longer and 1 inch wider?
Gene
  • PLUMMEN
  • PLUMMEN's Avatar
28 Jan 2011 09:59
#426476
you can pick up an early 90s gsxr 750-1000 arm for around $100 bucks without linkage/shock im guessing,just need to weld shock mounts on B)
  • TexasKZ
  • TexasKZ's Avatar
28 Jan 2011 10:06
#426477
The earlier GS1000 arms are also popular, though aluminum. Any reason you want steel?
  • TexasKZ
  • TexasKZ's Avatar
28 Jan 2011 10:12 - 28 Jan 2011 10:14
#426479
One item you will need to pay attention to is the axle diameter. It is best to stick with whatever fits the swing arm, which may necessitate some non-stock bearings or other trickery to make it all work together. You will likely need to fab spacers to insure a snug fit of the wheel in the arm and proper alignment of sprockets or pulleys. If you want to run a belt, carefully measure frame clearance near the swing arm pivot. The extra width of the belt may cause you a great deal of grief there.
Swing arm pivot bolt diameter is also an area of concern.
Last edit: 28 Jan 2011 10:14 by TexasKZ.
  • Kraz1
  • Kraz1's Avatar
28 Jan 2011 16:40
#426572
You also take the "Cush Drive" out of the equation by using that HD wheel. Not so good if your using Chain Drive.
  • Genius
28 Jan 2011 17:21
#426582
Steel...well I was thinking aftermarket and steel maybe cheaper?
Either way it will be painted black.
  • Genius
28 Jan 2011 17:25
#426585
Thanks, These are surly things I need to consider.
  • Genius
28 Jan 2011 17:32
#426588
Ya know that hadn't crossed my mind yet either!
My reasoning for running a belt is, one end or the other
is gonna need a sprocket or pulley.
Seeing how there's a pulley on the rim why not try to run the belt, I wouldn't miss the grease ;)
Tomorrow I should have a complete wheel to see whats goin on.
  • Genius
28 Jan 2011 17:45 - 28 Jan 2011 18:17
#426594
Thanks for all the response's!
Sorry I come in here empty headed.
I haven't owned or rode a Kaw in over 20 years,
kinda slid off the deep end to H-D...
Anyway with in 4 days I ended up with 2 KZ1000's:woohoo:
Work has had me locked down to 14 hr's aday so no shop time to look and think.
I can fab, cut, weld, little machine work...
I'll get it!
Thanks again.
Gene
Last edit: 28 Jan 2011 18:17 by Genius. Reason: spelling
  • stonemaster
  • stonemaster's Avatar
28 Jan 2011 17:51
#426597
actually gs 1100, the 82's are box 80 and 81 are tube
