1981 KZ1000 CSR
- cpg
02 Apr 2012 02:56 - 02 Apr 2012 02:59 #513517
by cpg
Current Bikes: KZ440 LTD and KZ305 CSR
Replied by cpg on topic 1981 KZ1000 CSR
To be honest I'm not sure what the 35 psi on your sticker is for but I looked up the fork air pressure in the Kawasaki service manual for our bike and it says the fork pressure is 5.7 to 8.5 psi. Is the 35 possibly a rating in kpa? Not sure what its for but I know that is too much pressure for the fork in psi. If you do decide to set the pressure get a hand pump with its own gauge so you can get it between 5.7 and 8.5 which is a small window. You also have to have the front end off the ground and try to get both forks as equal as possible.
Last edit: 02 Apr 2012 02:59 by cpg.
- nedrowjoe
02 Apr 2012 23:01 #513685
by nedrowjoe
Replied by nedrowjoe on topic 1981 KZ1000 CSR
Well now I am a little concerned to be honest. I am attaching a pic of the sticker, I hope you guys can read it. concern #1 now is that the forks on my bike have somehow come from another bike that allows a higher PSI, #2 if so the seals I bought for my stock CSR1000 are not right, If I tear them apart and the seals are wrong I'll really be screwed, I put some air in the other day carefully with a hand pump and a sensitive gauge and the forks did not hold air. so NOW, what do I do. my front shocks are shot!
- nedrowjoe
02 Apr 2012 23:02 #513687
by nedrowjoe
BTW it says 250 kpa
- MarkIsRadn
31 May 2013 23:44 #590193
by MarkIsRadn
Replied by MarkIsRadn on topic 1981 KZ1000 CSR
My understanding is the 'CSR' stood for 'Chrome Spoke Rims'. Your handlebars do look good on there. I've got some clubman bars on my '81 CSR. I would love to find an alternative to the red brick of a tail light that I have going on. I do like the chrome LED signals that I've found.
