- Thank you received: 11
80 KZ 1000 ST Recycled
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
17 Nov 2010 17:34 #413221
by gearheadmm
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
80 KZ 1000 ST Recycled was created by gearheadmm
Start with 1 $160 mechanics lien bike from local honda dealer. Remove dented coffin tank an' pitch. KZ 650 tank fell off the shelf an' landed right on it, cut the front tank pins .250" an' use same rubbers. 84 ninja 900 is a unique design with a small subframe that holds the rear suspension and bolts to rear of the engine. whittle some spacers an' tig it in. notice that this subframe has its own kick and centerstand. Add an extra motor mount so that dang bolt don't bend. more to come.
- gearheadmm
17 Nov 2010 17:41 #413224
by gearheadmm
Replied by gearheadmm on topic 80 KZ 1000 ST Recycled
- gearheadmm
17 Nov 2010 17:42 #413226
by gearheadmm
- Thank you received: 797
18 Nov 2010 07:44 #413280
by 531blackbanshee
Replied by 531blackbanshee on topic 80 KZ 1000 ST Recycled
this should be interesting.
very interesting.
are you keeping the shaft or changing to chain drive?
surely this is not the only pics that you have,is it :huh: .
keep us posted,
very interesting.
keep us posted,
- trianglelaguna
- Thank you received: 235
18 Nov 2010 08:33 #413285
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic 80 KZ 1000 ST Recycled
what he said.......any details on how the coversion from chain to shaft is done...
excellent so far....
1976 KZ900
2003 ZX12R
2007 FZ1000
- gearheadmm
18 Nov 2010 17:11 - 27 Aug 2012 23:00 #413355
by gearheadmm
I got cool pics but they gotta be scaned & shrunk, I,m workin' on it. One thing to note is this work was all done 8yrs. ago. [strike]This bike is for sale in the classified section[/strike] (witch you can't see if your not registered, if i'd a known) if you want to see the outcome. I didn't want to find out how much power a shaft would hold so that stuff on the floor followed the coffin tank, hope no one needed it. This will be chain. I was originally going to grab the mk2 engine an' call it a day, but closer inspection of the frame, mainly the extra 2" of clearance on the drive side where the swing arm goes in got the wheels rollin'. I had see a lot of wide tire conversions at the drag strip and they all had some form of hoakyness goin' on so this was the answer. Perfectly centered rear tire and straght chain. 5/8" ofset sprocket, support plate, an' 6" wheel, standard stuff. NO FRAME JIG 101. #1 Before you molest anything, have a plan. #2 before you molest anything, mark rear wheel centerline on the frame above rear wheel. #3 Molest away swingarm only, when you new arm/wheel meets the mark your good. #4 molest your rear sub/frame to the tire. #5 don't mess with the neck! Straight bikes don't tankslap an' don't turn west at 30lbs of boost. notice in pics above that the swingarm bolt goes through the shaft frame and the ninja subframe with the bearing bushings inbetween. Ninja parts are cool. Got somethin' for you chain frame guys too. more to come, out.
Last edit: 27 Aug 2012 23:00 by gearheadmm.
19 Nov 2010 07:58 #413416
by 531blackbanshee
oh great
the suspense is
FREAKIN KILLIN ME!
more pics less talk comon,:ohmy: :woohoo: :laugh:
the suspense is
FREAKIN KILLIN ME!
- gearheadmm
19 Nov 2010 19:38 #413491
by gearheadmm
I spent 4 yrs. buildin' this thing an' the suspense is killin' YOU! I've seen 2 types of mk2 cases chain & shaft. But the shaft cases will accept chain guts. The only parts you need are KZ/mk2 shift drum, shift fork shaft, shift forks, mk2 shifter shaft/lever, Mk2 output shaft, an' mk2 trans cover. Shaft cases have 2 shift fork shaft holes, be sure to put it in the right hole. Or do the GPZ conversion like I did. Big clunky don't break, almost as big as a busa trans, fit it 'n' forget it. Schnitz racing, R&D trans, or Gast can help. I also opted for the "all up" shift drum, neutral on the bottom, helps 1-2 shift cause there's no neut there. Index the neut light to light in 1st gear. don't forget undercut. This surfin' a lota work, pics soon, out
- gearheadmm
21 Nov 2010 18:02 #413723
by gearheadmm
- gearheadmm
21 Nov 2010 18:10 #413726
by gearheadmm
Startin' to look like somethin'. Check out how sweet the kick and centerstand came out. No more dragin' the stocker. Swinger done now I can mess with the frame.
- gearheadmm
21 Nov 2010 18:22 #413729
by gearheadmm
Chain frames heres a big fat bone for ya. This is my buddys bike. he used an 84 ninja 750 setup and did it very similar to what I did, it ain't big tire but very cool. I rode it, Very nice. Steering quite a bit quicker and more stable with that little tire on the front. Spring rates a little soft for my tastes, but better than a stocker.
- gearheadmm
21 Nov 2010 18:33 #413731
by gearheadmm
Heres the new front clip. KZ 1300 tree, 41mm tubes, stock brakes, stock rotors mounted to custom rotor hats, an' toped off with a magna fender. The 17" front wheel gives the stock brakes better leverage.
