KZ550 proposal
  • 82KZkid
  • 82KZkid's Avatar Topic Author
KZ550 proposal
10 Oct 2010 19:06
#405821
So i am wanting to do some frame/body modifcations on my 550LTD. One thing i have always liked on these older kawis where the rear tail section on the KZ's. However, i know that the frames of the LTD's and the KZ's are different. Was wondering if anyone has heard of cutting the rear section of a KZ's frame and welding to an LTD so that that rear section of the KZ can be incorporated into the LTD. Any and all criticizing is welcome. Thanks for the help guys
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: KZ550 proposal
10 Oct 2010 19:38
#405847
Some have added tails to LTDs, but did not weld on the rear section of the frame, just made mounts or zip tied to the existing frame.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • mjg15
  • mjg15's Avatar
Re: KZ550 proposal
10 Oct 2010 19:38 - 10 Oct 2010 19:40
#405848
You could probably weld the rear section from a std on the LTD, but if you get a seat and tail you could probably also fab what you need to hold it. The rear section only supports the body work and tail light. And, as mentioned in the other thread, you will need the side covers from the std model also.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Last edit: 10 Oct 2010 19:40 by mjg15.
  • 82KZkid
Re: KZ550 proposal
10 Oct 2010 20:51
#405881
Thanks a lot guys. However why exactly would i need the side covers? the tail section i found and was wanting to use is from a KZ400.
