81 GPz550 / ELR
  • mjg15
  • mjg15's Avatar Topic Author
Re: 81 GPz550 / ELR
27 Jan 2011 23:20
#426358
PLUMMEN wrote:
did you need to change any mounts to make the motor fit? B)
Motor bolts in. They are pretty much the same motor. The finning on the head is different, and so are all the case covers, but the cases and mounting points are the same.
You're right, the 550 does look like the Z1R, with the same square tank style. Very clean and simple.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: 81 GPz550 / ELR
28 Jan 2011 04:46
#426392
I don't want to burst your bubble, but you might want to look into replacing some of the original gaskets on that low mileage motor, before you start it up. Old seals and gaskets will seep, I have found out first hand, and not having to take that engine out to do it once it's in, might be something to think about.
-Head gasket, and side oval o-rings
-Valve cover gasket and cam end plugs(once you check the valve clearances, this will be buttoned up anyways)
-Oil pan gasket and o-rings(you can clean whatever is in the oil pan out, as time will have some kind of sludge in there)
-Left front trans cover gasket and both oil seals(this is a very common leak point)
These can be done with the engine still in the frame.
Just some advice here.
Project is looking good!!! I wish I could fab like some of you do, my race bike upgrade would be finished already. :S
'85 GPz550(ZX550-A2)
  • mjg15
Re: 81 GPz550 / ELR
28 Jan 2011 07:08
#426429
Corey,
Thats good advice for sure, and I have given thought to it. I have had a few problems with that before on some of my other old Kaw's, in fact they pretty much all seep some oil in one place or another. The problem is that I have a problem; I can never put anything back together stock once it comes apart. I did plan to do a valve adjustment and retorque the head, so for an extra hour of work I guess that it would make sense to pull the head and do the head gasket at the same time, with no carbs or exhaust installed it will go quickly.
How is your racebike update coming ?
I've been doing a little work on my SM racebike project too, but it has been so cold here that it's just not enjoyable to deal with the cold garage (and not practical to heat it).
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • CoreyClough
  • GPz550 Addiction
Re: 81 GPz550 / ELR
28 Jan 2011 07:47
#426440
I have tried the retorquing thing, and it doesn't, or didn't work. Replace the gaskets, and be done with it. The places I've listed are where I've seen it happen on used engines, and ones with low mileage as well.
Yep, I think most of us can't leave well enough alone. It's bread into us.
Racebike won't have the EX650 changes I want before AFM Round 1 March 19-20 at Buttonwillow, so I'll buy a new set of Avon Race Rubber, Galfer Green Pads, finish the Tarozzi Universal Rearsets, rebuild the front calipers, and do the basic race prep stuff. I will be installing and degreeing the Megacycle Cams in the current 615 engine, then getting it dyno'ed again at MCE Racing. Might reinstall the stock fairing too.
Now back to the topic at hand.
  • loudhvx
  • loudhvx's Avatar
Re: 81 GPz550 / ELR
28 Jan 2011 09:22 - 28 Jan 2011 11:29
#426468
mjg15 wrote:
Winter sucks !!
Took the words right out of my mouth / keyboard. :)
It's funny how a bike can look almost complete in a photo, but may only be 50% done time-wise. All the tiny details really suck up the time, with little apparent progress.
At least it's looking great!
mjg15 wrote:
and a gel battery (not taking any chances with my paintwork)
I'm in the same boat. I was taking out the battery for winter, and noticed this new battery was spitting up did some damage. So it's time to repaint the battery box again after 10 years.
But now I don't know what to go with. I've heard pros and cons about Sealed Lead Acid: Gel, and Absorbed Glass Mat. I was going to do a search and maybe start a new thread.
Have you picked out what battery you are going to use?
Last edit: 28 Jan 2011 11:29 by loudhvx.
  • mjg15
Re: 81 GPz550 / ELR
28 Jan 2011 11:34 - 28 Jan 2011 11:34
#426505
Lou,
I was considering a lithium polymer battery. You can replace a 10lb battery with one that weighs 1.25lb, and apparently has sufficient power. I have heard that they don't respond well to overcharging though. Do you know anything about them?
Heres a thread from the supermoto site: www.supermotojunkie.com/showthread.php?1...ight=lithium+polymer
You are right on about the small parts of the build taking a lot of time. So far I have about 100hrs into my bike, but I'm thinking that it will take double that to get where I need to be to finish. Thats a lot of hours in a COLD garage, so it will have to wait 4-6 weeks I'm afraid. Now that we have two feet of snow on the ground, I cant even move it into the basement for wiring unless I disassemble it.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 28 Jan 2011 11:34 by mjg15.
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
Re: 81 GPz550 / ELR
28 Jan 2011 12:13
#426521
Lookin great MJG15.....What exhaust will you be using if you dont mind me asking?
I dont think they make a kerker.
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • mjg15
Re: 81 GPz550 / ELR
28 Jan 2011 13:09 - 28 Jan 2011 13:11
#426537
I will be using a Kerker street megaphone system.
You are right, they no longer produce them, but thru my hoarding skills I have managed to end up with 3 systems (including 2 nos) and several muffler sections.
I'd like to find a race megaphone system, but I haven't yet.
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Last edit: 28 Jan 2011 13:11 by mjg15.
  • testarossa
  • testarossa's Avatar
Re: 81 GPz550 / ELR
28 Jan 2011 13:20
#426542
mjg15 wrote:
....sitting on it's own wheels/tires/suspension for the first time!
I'm glad that I was able to beat the cold weather and get pretty much all of the paint work done before winter.
Ahh it's the Z0.55R, this bike will draw some double takes.
For the record, I have AGM batteries in two bikes now, and I'm satisfied with the performance. They don't save any space or weight, but can sit for months with no charger, and not hardly lose any voltage. Very low internal impedance according to the sales info.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • M357.5
  • M357.5's Avatar
  • Kwakas N' lots of em'
Re: 81 GPz550 / ELR
22 May 2011 23:59
#452937
Any progress on this one mjg15 ?
This is one of my fave builds here.
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
  • mjg15
Re: 81 GPz550 / ELR
23 May 2011 00:55
#452950
Thanks,
I got sidetracked by selling a few bikes, one of which I ended up doing about 120 hrs work on. I wanted to get them sold early in the season, while the selling prices are the highest, so that became the priority.
Another GPz550 that I bought has a bunch of motor work, I may swap that motor for the stock ZR motor. The other motor has a big bore kit, cams, ported head, and Keihin cr29's. It looks like I may a have a bit of time next week to spend working on it, I'm hoping to get it done sometime in June. I have to do the electrics, fabricate brackets for the headlight and instruments, and few (dozen) other small details. I'd like have it ready in time to make it to the KZ1000R.com ride in Vermont on 6/11, but I'm not sure if I will be ready for that.
How's your 650 project coming along?
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • wireman
  • wireman's Avatar
Re: 81 GPz550 / ELR
23 May 2011 00:58
#452951
Attachment popcorn_2011-05-22.jpg not found
