setting fuel level
  • bullitt
  • bullitt's Avatar Topic Author
setting fuel level
05 Aug 2010 10:20
#388367
hi guys can the fuel level be set using the clear
tube method on the bench without having the carbs
on the bike my carbs are keihn cv34 have bought a
rebuild kit for them they havent been touched for
29 years cheers
  • TerryK
  • TerryK's Avatar
Re: setting fuel level
05 Aug 2010 10:24
#388369
Should be able to dry set them on the bench as per the service manual.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • apbling
  • apbling's Avatar
05 Aug 2010 10:40
#388373
I thought of trying to do something like this, but I think you'll get better results just by putting them on the bike and checking the fuel service level. It's not too bad because you don't have to connect the air box ducts or any cables... Just put the carbs in the holders, put the gas tank on loosly, hook up the gas and start measuring.
I recently got bit by the float height bench method on my 550. They all looked just fine and the same height, but #2 was WAY lower actual fuel level.
05 Aug 2010 12:14
#388394
29 years cheers
YES.
Keep the carbs level while clear tube testing.
Good Fortune! :)
  • JMKZHI
  • JMKZHI's Avatar
06 Aug 2010 05:35
#388590
Yes. I use a homemade carb stand w funnel & tubing as an auxiliary fuel supply.
PS: sometimes the inverted/dry method doesn't yield the correct fuel level. It didn't for me.
