What's next?
  • Serpent7
  • Serpent7's Avatar Topic Author
  • Nothing professionally, only for fun...
What's next?
03 Aug 2010 05:17 - 03 Aug 2010 05:20
#387860
I have a 79 KZ1000 st,, which I just got up and running. It's pretty much all stock accept for the 4 into 1 used exhaust, sport handle bars, and side bags removed. I changed all the fluids, bleeded the brakes, rebuilt the carbs with a car kit, drained the gas and put in new gas and the bike came right on after sitting 5 years with PO! I still have some fine tuning to do with the carbs but all in all the bike runs very well. However, it has a rough idel and dies if you come to a stop. At around 2500 rpms it sometimes shoots flames out of the exahust. As cool as it may sound I dont think it should be doing that, so Im guessing (I dont have much experience with motorcycles) its running rich! Al it makes loud popping sounds while riding every now and then. My question is I want to get it running right so where should I start now? tune up kit? accel super coil kit?
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
Last edit: 03 Aug 2010 05:20 by Serpent7. Reason: fixed
  • Old Man Rock
  • Old Man Rock's Avatar
Re: What's next?
03 Aug 2010 05:26 - 03 Aug 2010 05:28
#387862
First thought is your running lean not rich...
Does it pop out the exhaust on decelerations?
example: Driving at 65mph, let go of the throttle, does it pop-popity-pop....?
Before worrying about jetting, have a vacuum leak at the intake manifolds?
Biggest thing to accomplish first.... CARB SYNC!!! ;)
Pop out the plugs and confirm their condition...
How to read sparkies correctly...
kzrider.com/index.php?option=com_docman&...d&gid=460&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 03 Aug 2010 05:28 by Old Man Rock.
  • Serpent7
Re: What's next?
03 Aug 2010 05:34 - 03 Aug 2010 05:37
#387863
yes, it pops during declerations...
I have K&N individual air filters on it now.
Ill pull the plugs when I get home tonight from work and school.
19 Audi Q5
73 Volkswagen Thing
Last edit: 03 Aug 2010 05:37 by Serpent7.
  • Old Man Rock
Re: What's next?
03 Aug 2010 05:45
#387866
"However, it has a rough idel and dies if you come to a stop. "...
Turn your pilot screws "Rich" a 1/4 turn and see if that takes care of your idle issue...
Speaking of which, where do you have the pilot turns at now, OEM spec?
Regarding the Pods, did you just install these?
If so then jetting most likely required as well....
Same with the 4-1 exhaust, is this a new addition?
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: What's next?
03 Aug 2010 06:39
#387871
Like already said, if you have K&N pod filters and a 4-1 exhaust, you have changed the fuel requirements of the engine drastically.
This means the carburetors require tuning in order not to damage the engine further.
If you have rebuilt the carbs, then you should be fairly familiar with them, and this will likely be not too difficult.
My best recomendation for persons not familiar with tuning carbs is to simply purchase a Jet Kit for your bike. The kit comes with all the tools and parts required to jet the carbs exactly for your situation. if you start just buggering/guessing with jets, you will spend a long time fiddling with it, and not riding.
Contact Z1 Enterprises for which kit to order. they are very helpful/accomidating.
GL!
B)
PS. On my bike, I have to completely remove one of the mixture screws to make it pop a flame out the exhaust.
Check for it...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Re: What's next?
03 Aug 2010 06:52
#387873
Serpent7 wrote:
I have a 79 KZ1000 st...4 into 1...rebuilt the carbs with a car kit...new gas and the bike came right on...runs very well. However, it has a rough idle and dies if you come to a stop....
rough idle and dies if you come to a stop --- would suspect pilot circuits and/or valve clearances.
Good Fortune! :)
  • TerryK
  • TerryK's Avatar
Re: What's next?
03 Aug 2010 07:55
#387882
I concur with my compatriots, lean throughout the rpm range, and a possible plugged idle circuit/valve clearance problem.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
