Custom '81 KZ1000 Project
- amele7
25 Jul 2010 13:13
Picked up a new project....Bike was previously re-built...guy I bought it from bought it as-is and bike stopped running one day and guy let it sit for the past two years....Cleaned carbs, found a wire on the coil that came off and bike started up and ran....now just need to change a few things that were half-ass like a harley 1"bar front master cylinder! shimmed to fit 7/8 bars.
Needs new rotor/flywheel- magnets are broken/missing
Front master cylinder
New chain/sprockets
right cam cover
mps kill switch w/cord
New Tires
powder coat a few parts
new paint
new seat- don't like current style
re-do tail w/new light/tag bracket under the tail
need turn signal switch/ new starter switch/throttle tube
Bike already has:
K&N pods
Sidewinder pipe
extended swingarm
ninja rear wheel w/190 tire
custom front wheel...Invader wheel? not sure
few more pics here: s131.photobucket.com/albums/p290/amele82/KZ1000/
New chain/sprockets
right cam cover
New Tires
new paint
Bike already has:
K&N pods
Sidewinder pipe
extended swingarm
'79 KZ650B3
'81 KZ1000J
'81 KZ1000J
- amele7
Re: Custom '81 KZ1000 Project
25 Jul 2010 13:33
Anybody use a hayabusa front end on a kz? A buddy of mine has one I can use but not sure if it will work.
'79 KZ650B3
'81 KZ1000J
'81 KZ1000J
26 Jul 2010 09:30
cool project.i can't wait to see what you do with it.
- porchev914
26 Jul 2010 11:25
It can certainly be done, it's no different than any other front end swap
FRANKEN Z!
- amele7
12 Feb 2011 08:00
After a long season coaching football and the holidays, I finally made got some time to work on the KZ....Decided to swap the front end and bought an '05 636 front end and rear from a friend who was parting his bike out. Gotta get the stems mailed out to leon(513blackbanshee)so they can be swapped. Then offset front sprocket and rear wheel spacers made.
'79 KZ650B3
'81 KZ1000J
'81 KZ1000J
- z650c3
12 Feb 2011 12:18
Looking good amele7 , very interesting project you have on the go there . I like it .
C3
C3
1979 z650 c3 first registered in 1981
2006 Harley Davidson VRSCR
Northern Ireland
Northern Ireland
- camaroguy
12 Feb 2011 12:39
nice job. front end looks good on there.I like the late kawasaki wheels.
- porchev914
12 Feb 2011 13:54
oooooh, I like the red anodizing on the fork tubes!
Keeping the dual shocks makes things simpler as far as installing the bigger rubber in the rear. Keep it up!
FRANKEN Z!
- amele7
13 Feb 2011 15:18
the anodizing is gonna be history since I'm going with a new color scheme...although not sure which colors yet....Most everything is gonna get powder coated besides the plastic....left the dual shock setup primarily because of simplicity and struts would probably make the ride way to rough.
'79 KZ650B3
'81 KZ1000J
'81 KZ1000J
- dejavoodo41
13 Feb 2011 15:34
My bike had struts on it when I bought it and it only took 1 ride to convince me to put shocks on the back. It was in 2 words very painful at freeway speeds on expansion joints.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
14 Feb 2011 06:50
the late model kaw wheels like the front are really sweet,imho :laugh: .
what colors are you going with?
- amele7
