Here she be
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Here she be
20 Jul 2010 19:06
#384191
ewwwwwwwwwwwww.... :angry:
You're going to pay heavily for that one sunshine..... :P
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Kitten Tooth
  • Kitten Tooth's Avatar Topic Author
Re: Here she be
21 Jul 2010 00:52
#384286
okay, new chain and sprockets are ordered.. She would barely go around the block. God only knows what would have happened if i would have kept on givin er' hell on the way home.. the chain was actually skipping teeth it was so loose and stretched out:/ On my first ride i found that the chain was so tight that there was absolutely no play at all. The person who owned it before me brought the wheel back the the second mark on the swing arm from the end... WAY TO TIGHT!!! i rode on it like this for like 2 or 3 days before i discovered this while backing my bike out without the engine on.. i could hear the chain grinding and popping its way onto the teeth of the sprocket.. i went around the block today on it and it was like riding diagonal. if you gave it any gas, it would either slip or start to walk to the right.. Axel and adjusters must be very loose.. you can tell by looking at the O-ring chain that it is dead.. most of the o rings are missing and the sprockets are wore out really bad..
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
Re: Here she be
21 Jul 2010 00:54
#384287
swing arm bushings have little to no play and the wheel spins freely without the chain on so its not barrings either.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
