78 KZ650 rebuild
  • baldy110
  • baldy110's Avatar Topic Author
78 KZ650 rebuild
17 Jul 2010 15:16 - 17 Jul 2010 15:23
#383382
Here is the 7th tear down and rebuild my 78 KZ650. This time I did it the way I always wanted to without cutting corners. Warning lots of pics.
Last edit: 17 Jul 2010 15:23 by baldy110.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 78 KZ650 rebuild
17 Jul 2010 15:19
#383384
cool,going with red bodywork again? B)
  • baldy110
17 Jul 2010 15:27
#383386
Yeah I like red but this time it's Guards Red and I made sure it was perfect lots of color sanding and polishing.
  • Mark Wing
  • Mark Wing's Avatar
17 Jul 2010 16:40
#383402
Man that looks GREAT, nice job. So when well you be ready to go for a SoCal ride to show off in person. I like the old Russ Collins pipe and I use to have my badges like that, nice.
Mark
Yorba Linda Cal.
  • PLUMMEN
  • PLUMMEN's Avatar
17 Jul 2010 16:46
#383406
oops,the pictures werent all up there first time i saw it! :laugh:
  • cobura
  • cobura's Avatar
  • forever 2 wheels
17 Jul 2010 18:00
#383453
thats really nice! good work.
Where did you find those backsteps? Did you make them or buy them?
1979 KZ650B3
  • baldy110
18 Jul 2010 17:50 - 18 Jul 2010 17:59
#383700
Thanks guys, and yes Mark I would like to go on another ride with you guys. I always have a good time, any idea when the next one will be?
If your referring to the "backsteps" as the rearsets, I fabbed those up. I used a 1976 Honda CB400F gear selector for the shifter side and lengthened the shift rod. Believe it or not but the splines for shifter on the the CB were the same as the KZ.
I used an old shifter lever for the rear brake and welded up the bolt hole then drilled it out the splined section to accept a smooth shaft. I cut the stock rear brake pedal and fabbed it to work. I bolted both sides to the stock passenger peg arms using plates I fabbed from aluminum.
Last edit: 18 Jul 2010 17:59 by baldy110.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
18 Jul 2010 19:19
#383731
Love it.
Like how you did the badges, and all the other attentions to detail.
B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
