should I cut here?
- btkz650
should I cut here?
12 May 2010 04:05
I'm building a bobber and want to fit a peanut tank to my kz1000 frame but the frame is in the way of the petcock. Does anyone know if I cut a section out (shown in yellow on the attached) and weld another piece going from the lower section to the top section much like the factory did just to the right of the yellow, would that be strong enough? I'm just not sure how structural the two lower pieces are since they are tied to the top section of the backbone.
- Jodyb17
Re: should I cut here?
12 May 2010 04:16
I am pretty sure that bar is structural. The backbone actually connects to the side bars in term of force resistance. Not sure how effective moving the connection location would be.
Is the tank painted already? I would think it easier to modify the tank or tank mounts than the frame. Make sure you have all the gas out before you put heat to it.
1977 KZ 650 C
- PLUMMEN
- otakar
12 May 2010 08:45 - 12 May 2010 08:46
You can cut anywhere your Lil-Ol-Fuzzy-Heart desires. I just don't want to be around when you ride it. And if I am, I want to be in front of you. :ohmy:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 12 May 2010 08:46 by otakar.
12 May 2010 09:23
Flexible flyer.
- trianglelaguna
12 May 2010 09:27
absolutely.......in fact......when researching things that may cost me my very life...i often seek out the advice of internet strangers.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- trianglelaguna
12 May 2010 09:33
no
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- btkz650
12 May 2010 10:36
Okay okay, I get it. It was a really ridiculously stupid question. Guess I already knew the answer but was hoping to hear something that would allow me to use the tank I just bought. I've seen them used on other similar KZ and GS bobber projects and thought it would fit, but they must have done something different to make it work. Must have relocated the petcock on the tank is all I can figure.
- 9am53
- homebrew, and some bbq
12 May 2010 11:12
...said the rabbi
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
12 May 2010 12:44
btkz650 wrote:
Not really. It would only have been a stupid question if you had asked it after cutting the frame.
12 May 2010 14:17
ask wompy if he can tell you how his was modded to fit.
jpriderdesigns.blogspot.com/?zx=63af4195b5a9da86
he has a chopped 650 with the same kinda tank.
hth,
hth,
- TeK9iNe
- What did you do!?!
12 May 2010 14:19
trianglelaguna wrote:
:laugh: :laugh: :laugh: :silly:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
