Bobber project needs steering stem bearings
- btkz650
11 May 2010 06:19
Hi, I'm a newbie working on a KZ650 bobber on a KZ100 frame. I have the steering stem from a 650 with bearings but can't find the two pieces that fit into the neck of the frame before you insert the stem and bearings. Anyone know where I can get them and what they are called? I bought a newer set of tapered bearings and they fit the neck of the frame but not the stem. Help!
Thanks,
Bryan
Here's a pic of her.
Thanks,
Bryan
- lewisj
Re: Bobber project needs steering stem bearings
11 May 2010 06:35
Bryan,
I think your talking about the "races". They should come with the bearings when bought new. The races will fit snuggly into the triple tree neck. I had a similar situation with a Suzuki stem and kawasaki neck. I made measurements of the neck and stem, called "all balls" bearings and they sent me the proper bearings and races. Just google up "all balls" and they are good to work with.
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- btkz650
11 May 2010 06:39
Thanks for the reply Jim. That's where I got the new tapered style bearings. The races fit into the neck of the frame but the inside diameter of the new bearings won't go over the top of the steering stem.
- lewisj
11 May 2010 06:53
Measure the diameter of the stem and see if all balls can amtch the innere and outer specs, they did for me.
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- btkz650
11 May 2010 07:40
Good idea. I'll have to send mine back to them anyway. Thanks.
- Bad Dad
11 May 2010 07:51
Here's a pic of her. [/quote
Very nice... keep us posted, and post more pic's when you get a chance!!
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- Kawickrice
11 May 2010 10:43
The early 650 and 900/100 bearings are identical. Either they sent the wrong bearing or your tree and frame are not what you believe them to be.
My .02
My .02
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- btkz650
17 May 2010 03:46
It looks like they sent me the wrong bearings for a KLR250. Sending them back.
- hmeric7
22 May 2010 22:01
did u rake out the fornt end or swith forks out with soemthing else. just kinda looks like its raked.i love the way its looking. ima bout to do this to a 550 i picked up
1977 KZ 1000 LTD
