'78 KZ1000 makeover
  • porchev914
  • porchev914's Avatar Topic Author
Re: '78 KZ1000 makeover
29 Jul 2013 22:18
#599002
Hmmm, not a perfect match, but I DID darken the paint a bit with the candy (which, btw, isn't very noticeable if at all). OK, that will do. But how will it look with a black tank? So I set the raggedy prototype carbon tank shell on there to see.
I think I can live with that :woohoo:
FRANKEN Z!
  • DoctoRot
  • DoctoRot's Avatar
29 Jul 2013 22:39
#599006
lookin good! i was thinking about your CF tank the other day. I know you were having trouble with getting the CF to stay in place before you could bag it for the top mold of the tank. If you split split the tank into 3 mold sections, top left, top right, and bottom. I dont think you would have any trouble getting the CF to stay in that scenario. Although you end up with a seam in the middle of the tank. but then you just paint a sweet racing stripe down the middle to hide it. like so.
  • Haybus
  • Haybus's Avatar
  • Big Al
29 Jul 2013 22:45
#599007
That looks really good. No disrespect on the clear coat. Probably fine if it's not out in the sun all the time. Clear coats have UV inhibitors but they can't block because they're clear. Eventually the sun will get to the resin given enough time, the clear just slows the clock.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • porchev914
29 Jul 2013 23:01
#599013
Well yeah, no coating is forever! I wonder what happens faster, rust eating a tank or UV embrittlement of resins? Either way, if my tank has some issue down the road, I'll just make another one B)
Doctorot, that is a sweet looking tank! Thanks for thinking of me, and the suggestion. I will eventually have to make another tank mold, and when I do I will consider a 3 piece top unit. Before I do that, I will run some infusion experiments with the current mold. The biggest issue I had was the sheer size of the pieces of cloth I was working with, and the amount of time it took to do a wet layup necessitated a slower cure resin. That was a large part of my issue, plus the cloth not staying put. In an infusion, all the cloth is placed dry, so I can either tape or use spray adhesive to keep the cloth in position before bagging and pulling a vacuum THEN introducing the resin. If that fails to work, then I'll try something like you suggested, so thanks ;)
FRANKEN Z!
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
30 Jul 2013 10:12
#599057
the porsche sounds pretty wicked :evil: !
that painted frame has been a long time coming :whistle: ,congrats on that.
  • porchev914
30 Jul 2013 11:33
#599072
I know your not a fan of anything other than black frames Leon :whistle: At the moment, I'm simply happy there's paint on it. Thanks for the kind words, the Porsche sound wicked because the cam doesn't like to run under 5k rpm :pinch: As soon as the KZ is a permanent roller, I have a new (smaller) cam and smoother clutch to put in her.
I got my cases pressure washed last night to clean out all the threaded holes and started running a cleaning tap through everything.
FRANKEN Z!
  • 531blackbanshee
  • Vendor
30 Jul 2013 11:38
#599073
porchev914 wrote: I know your not a fan of anything other than black frames Leon :whistle:
true :lol: .
but the first thing i ever painted was my jeep tonka toy in the early seventies,i used copper colored paint :laugh: .
so i am somewhat partial to copper :whistle: .
it is a metal color and that goes along way on frames .
  • porchev914
31 Jul 2013 02:14
#599172
I am wondering if the engine would look better black in the copper frame.....Oh well, I have plenty of black on the bike already. The engine looks so pretty, it'd be tough to paint over it :laugh:
Other than that, just keep rollin' rollin' rollin'....
FRANKEN Z!
  • 531blackbanshee
  • Vendor
31 Jul 2013 09:59
#599198
  • testarossa
  • testarossa's Avatar
31 Jul 2013 16:07
#599251
[IMG
I think I speak for everybody when I say we need to see a video of that Porche tearing down the street. :evil:
Glad to see you back at it. I just about thought this one might not ever come together. Keep up the good work.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
31 Jul 2013 17:09
#599259
Sorry for the late reply to this thread, but I just found it! :S
Curious to find out how your CF tank holds up. Did you line it with anything, or is it raw? I have one on my framer and I don't want to line it, or for it to delaminate, so I drain the fuel after every race.
[IMG
  • porchev914
31 Jul 2013 21:15
#599317
Oh Leon, you're such a slave driver! Thanks for dropping in Josh, and yeah, I had my concerns as well. Not from a technical perspective, but a time and resource commitment. It always seemed there was something else more important. As for a video of the car ripping around...all in good time ;) Priority 1 is to get the Kz into a permanently assembled roller. Priority 2 is to finish off the major bodywork items on the Porsche. Priority 3 is the cam and clutch replacement. After that, I'll make you guys a little video :evil:
Slayer61, thanks for stopping by. The task I have here is a non working prototype. It's an unbonded top and bottom piece. I had planned to just hang that one on my wall, but it would make for a great experiment to affix a cap, fill out with pump gas and let it sit to see what happens.... I might just do that, thanks for asking B)
FRANKEN Z!
