- Thank you received: 13
Testarossa's 78 KZ1000 Fighter Build
- Bad Kaw
- Flying Squirell
S ituation
N ormal
A ll
F ____d
U p
:laugh:
Exxxxxxxxxxxxxactly!
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
- testarossa
- Thank you received: 82
I laid the motor on it's side on top of an old tire and dropped the frame in place over the top. Thanks to my frame bracing, I have to remove the carbs and the camshaft cover. Most of my mounting bolts need to be replaced, but hey it's in.
I also received my new fork springs this afternoon. I went ahead and installed them before I started playing around with the motor. So now the front suspension is all squared away. Fresh grease in the new roller neck bearings, new fork oil, proper springs per race tech calculations, and new fork seals. I think that I may take my top clamp to work and mill a little material out from the bottom to allow just a little more height up front.
On a sad note, I crunched one of my new cam end plugs while changing shims. I was a dumbass and laid it beside a cam lobe and when I started to turn the motor over to check a different valve, CRUNCH! Or as Leon would say SNAFU, cattywampus, or wamperjawed.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Bad Kaw
- Flying Squirell
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
- Nelson
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- porchev914
- Thank you received: 19
Good work getting the engine in solo, did you chip your new paint at all?
FRANKEN Z!
- larrycavan
- Visitor
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
Fantastic Josh. Bummer about the cam plug, was it a fancy aluminum one? If it was, I bet someone here has a spare. If not, I have a set from APE I can send you. I'm not going to need them any time soon :whistle:
Naw it was a plain ole black rubber coated plug. No need to send me your APE plugs, I need to order from Z1 anyway. I may have put a small ding in one of my brace tubes, but I couldn't really tell last night. I was soo tired and the light is terrible in my garage. I expect to have to touch up some areas, that's why I wanted the semi-gloss. I'll probably know more when I can get the wheels under it, and roll it out in the sun.
2004 ZX-10R
Angola, IN
- porchev914
FRANKEN Z!
- testarossa
At this point it is what it is. You're picking up speed now, and I'm gonna go out on a limb and say you have a first start in 3 weeks
I hope you're right. I want to ride with my father-in-law at my wife's family reunion at the end of October. I may just have enough time to assemble and get it tuned.
2004 ZX-10R
Angola, IN
- testarossa
2004 ZX-10R
Angola, IN
- PLUMMEN
- Thank you received: 104
