73 z1 chop rebuild
- KLD
- Iron Duke
- what are you rebelling against?
Re: 73 z1 chop rebuild
22 Dec 2009 22:41
Something else! a nother screamer.Welcome to KZR nation regards Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- chance
- Life long biker/
23 Dec 2009 06:25
Welcome to the forum ..That should be fun to ride .You don't see many Z1 chops anymore.......We would like to see those pics that didn't come out..Have a good one
- roy-b-boy-b
- KLD
- roy-b-boy-b
24 Dec 2009 14:15
You can spray some carb cleaner on the shim and it will disolve the oil under the shim then use compressed air or a dental pick to get it out.
Are you keeping the shims and other parts together with the cylinder it came out of? Roy
- KLD
31 Dec 2009 12:10
cool old chop!keep us posted.
leon holmes
leon holmes
- KLD
- KZ250LTD
01 Jan 2010 20:01
KLD wrote:
Buy two regular ring compressors (~$10 each) and do two cylinders at a time. Turn the engine over a little so two pistons (either 2&3 or 1&4) are at the top of their stroke and the other two are at the bottom. Get the higher two into their cyls , turn the engine over some more and repeat
I don't have the "special" tool they recommend to compress all 4 piston rings while I slide the jugs back on. Is there another way of doing it?
79 KZ1000ST
Past:
Many.
Past:
Many.
- KLD
27 Jan 2010 14:26
looks good,it is coming back together nicely.you need all the shims you can get if you are going to keep this bike.they are a pain,but you gotta have them.i have robbed shims outta heads for years to get my selection and still need more.sorry i don't have a good word for ya on where to get them tho.
keep us posted,
keep us posted,
