73 z1 chop rebuild
- KLD
- Iron Duke
- what are you rebelling against?
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- chance
- Life long biker/
- roy-b-boy-b
- Thank you received: 103
- KLD
- roy-b-boy-b
Are you keeping the shims and other parts together with the cylinder it came out of? Roy
- KLD
- Thank you received: 797
leon holmes
- KLD
- KZ250LTD
- Thank you received: 16
I don't have the "special" tool they recommend to compress all 4 piston rings while I slide the jugs back on. Is there another way of doing it?
Buy two regular ring compressors (~$10 each) and do two cylinders at a time. Turn the engine over a little so two pistons (either 2&3 or 1&4) are at the top of their stroke and the other two are at the bottom. Get the higher two into their cyls , turn the engine over some more and repeat
79 KZ1000ST
Past:
Many.
- KLD
keep us posted,
