KZ 550 It's ALIVE!!!!!
  • speedyneo
  • speedyneo's Avatar Topic Author
24 Nov 2009 08:08 - 24 Nov 2009 08:12
#335611
Well i recently picked up a 1980 Kz550a that i found in a barn.It has 20k miles on it and hasnt been run in at least 10 years. I have rebuilt the starter that was fried cleaned everything up and put new coils on it and i finally got it running and it runs pretty good.:cheer:
Now here's the ? do i tear it down and go thorough it or just clean it up give it some paint and hope there is no other problems? I dont mind having a winter project but i dont really know what im geting into im kinda new to motorcycles but i am a mechanic.
I welcome any opinions and advice please!!
If i do a complete rebuild i would like to put dual disk on the front,Pods,and new 4in1 exaust also i need to lower the bike about and inch
1980 Kz550
Pratt,Kansas
Last edit: 24 Nov 2009 08:12 by speedyneo.
  • timebomb33
  • timebomb33's Avatar
Re: KZ 550 It's ALIVE!!!!!
24 Nov 2009 08:24
#335613
if your a mechanic fly in to it and see what makes it tick that's best way to learn from what i've seen myself personally do your self a favor and get plenty of good info and do some investigating it what is still available as far as parts supply's and then fly into it if you hadn't picked up this bike it would still be in some rotting so any you do will be an improvment right
I THINK MY POWERBAND BROKE
  • Old Man Rock
  • Old Man Rock's Avatar
24 Nov 2009 08:30
#335616
Good for you! B)
Now first thing to do is... now pay attention to what we're telling you is as follows....
GET THE KAWI SERVICE MANUAL! ;)
Study and learn your beautiful girl... KZ... Love her :kiss:
Now that you have that accomplished...don't cheat... Accomplish a compression check, leak down check and valve clearance measurements... This will inform you that you have compressions within specifications...
Change the oil and filter...
You may also need to re-build your carbs... Hell, if they have been sitting there for 20 years, definitely open them up for a good cleaning.
Tank, rusty or clean internally! Kreme if required...
Install new fuel lines and in-line fuel filter...
Sprockets and chain, good or worn! Replace if required!
Brakes, at least bleed and change the fluid...
Electrical charging system, regulation and voltage measurements & checks....
New Battery...
Check your ignition timing... Replace points & condensor... Or replace with EI if available... Not sure on a KZ550 others can chime in... If not, for as little as they costs, replace them and re-set the timing.
Tires? cracked, bubbbled etc... Ah hell, just replace due to age and dry rot...
Jeff @ Z1 for parts...
Z1enterprises.com
Let's see guys, I forget anything?
Way to go... :woohoo:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • speedyneo
24 Nov 2009 08:41
#335620
Ok I already have the manual and have checked on lots of parts as for the basic maintenance i have already done all of that but the compression,leak down, and valve clearance check planing on doing that this weekend. Oh and it does need new tires BAD lol thats the only thing keeping me from driving it LOL
1980 Kz550
Pratt,Kansas
  • Kawickrice
  • Kawickrice's Avatar
24 Nov 2009 08:43
#335622
:woohoo:
Clean lube and inspect cables :)
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • speedyneo
24 Nov 2009 08:56
#335626
Kawickrice wrote:
:woohoo:
LOL funny you mention that if only i would have asked this question before i started it would have saved me $30 i checked brakes and clutch and adjusted and lubed but forgot about the spedo and tach now i have to replace because they were rusted and broke!!
Live and learn right!!
1980 Kz550
Pratt,Kansas
  • speedyneo
24 Nov 2009 08:58
#335627
Oh and this might be a stupid question but why does the ignition switch have 2 lock positions it goes lock off on lock ???
1980 Kz550
Pratt,Kansas
  • Kawickrice
24 Nov 2009 09:04
#335628
Parking lights. or fork lock probably
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
24 Nov 2009 09:46
#335636
Change fork oil.
  • roccbottom
  • roccbottom's Avatar
  • 1984 gpz1100, 1995 kz1000p
24 Nov 2009 10:36
#335643
You know what fellas, That list could be very helpful To any one, trying to figure out where to start a rebuild or, resto project. I know I've seen that question posted numerous times, maybe in a F A Q section. what do you guys think?
