KZ440 Winter Project
- mwriders
- if I only had a brain
10 Oct 2009 10:29 - 10 Oct 2009 10:42
Here's a winter project in Lincoln, NE. 1981 KZ440B. It gets a B+ for cosmetics. Filthy, but not much rust except for the fork tube tops (damn fork ears). Needs a petcock, carb work, air box (or something)and it ought to run. The electrical stuff all seems to work, which is good since she's electric start only. So, step 1 is to deal with the fuel issues, push the button and see what happens.
1980 Kawasaki KZ440B (brand new eBaby)
1998 Ducati 900S (gone)
1978 BMW R100S (gone, damn it)
1975 Yamaha RD350 cafe (gone)
1986 Yamaha XJ650 Seca (gone)
1981 Kawasaki KZ440LTD (gone)
1969 HD Sportster (gone
1966 Honda CB160 (gone, damn it)
1965 Suzuki 80
1965 Suzuki 80
Last edit: 10 Oct 2009 10:42 by mwriders. Reason: altered picture
- mwriders
Re: KZ440 Winter Project
10 Oct 2009 10:46 - 10 Oct 2009 10:49
Here's the left side. Note that there is no brake cable. The guy that I got it from had disconnected it and removed the bake lever, on the grounds that he had never used a front brake and they are useless, anyway. Really. It's kind of disconcerting moving the bike around as I'm forever reaching for a brake that doesn't exist.
1965 Suzuki 80
1965 Suzuki 80
Last edit: 10 Oct 2009 10:49 by mwriders. Reason: resized image
10 Oct 2009 11:24
Before you try to start it, you may want to change the oil & filter then pull spark plugs and spin the motor with starter to get some oil circulated through the motor.
- mwriders
10 Oct 2009 11:28
Plugs and oil are new, and the timing has been set on new points (although I'll check them again). The condenser is supposedly out of some kind of Chevy. The lead is about 3-feet too long, but it seems to work. Oil pressure sensor is supposedly a Honda Civic item. It also seems to work, or at least the idiot light does.
1965 Suzuki 80
1965 Suzuki 80
