77 KZ650C Bobber Project
- JonnyC
Re: 77 KZ650C Bobber Project
17 Oct 2009 14:50
yuvalbo1 wrote:
if you mean like hardtail then yes i will be doing that next winter with the help of the tigman.
other than that just going to lower the rear a bit and maybe the front. possibly re paint the frame
cool man, what you plan on the Frame?
1977 KZ650C
- JonnyC
19 Oct 2009 13:11
christmas in october, got this stuff today. waiting on the breather filter for the crankcase. which sucks since i ordered it friday and the guy might not ship until wednesday
1977 KZ650C
- JonnyC
25 Oct 2009 12:02
Put the pods on, changed the oil and filter, wd40d some parts that were a bit stiff. im still in the process of cleaning the inside of the tank, but will buy a fuel filter of course. will be getting a battery tomorrow, then have to take those spark plugs off so i can put a tiny bit of oil inside. once thats said and done im hoping to start the engine. and if im lucky it will turn on. obv with the pods it probably wont stay on but knowing that it could turn on will be ok. I really want to start bobbing it out.
pics to come soon
pics to come soon
1977 KZ650C
- thompsonmx100
25 Oct 2009 14:40
the pods wont keep the bike from running it will be lean but wont die on you. Do you have the stock exhaust? If not that 4-1 will make it a bit mor lean but still won't make it quit.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- JonnyC
25 Oct 2009 16:13
thompsonmx100 wrote:
yeah all i have is that 4-1 with no baffle. need to find me one.
but yeah i just want it to run for a little so i know the engine is good an not need an overhaul. after that ill rejet and clean that bike head to toe while bobbing it.
also i need to check the wiring, i used a 12vlt 6amp charger to see if the electrical worked. the neutral light turned on and the brake like and horn worked but the headlight and signals didnt turn on. i chekced them all and they are all new bulbs. i know under the headlight there is a pkug that isnt connected and i cant find where it connects too.
1977 KZ650C
- JonnyC
29 Oct 2009 16:11
Tried starting the bike today, sounded good. at first gas wasnt going into the carbs, then i got it set. it tried starting but nothing, went to the point that i smelled gas, i sniffed the exhaust i smelled gas so i stopped. i have to check if there is spark going to the plugs and if the plugs are good.
Also none of my lights turn on nuetral turns on and when i press the brak it lights up bright but nothing else turns on and they are all new bulbs. so it will be fun checking all that wiring, which i want to replace this winter but i want to make sure the bike runs and works fine so i can start actually bobbing it out
1977 KZ650C
- JonnyC
02 Nov 2009 12:48
Not much of an update, but my bike so far.
a fellow kzrider, fixer5000, drove over and sold me ignition coils, 25 for both
futureuntold.wordpress.com/2009/11/02/bike-at-the-moment/
1977 KZ650C
- YUKABODOS
02 Nov 2009 15:08 - 02 Nov 2009 15:11
A couple of suggestions:
Check and replace fuses. May consider converting to blade type fuses. (May solve lighting issues) Also check ground wires.
Buy some new spark plugs. I just brought a 650 C back to life and the plugs needed to be replaced. At least the $12 is worth peice of mind knowing that they are good and new.
Maybe unscrew spark plug caps and trim back the plug wires an 1/8 to a 1/4 of an inch to remove any corrosion. If you see shiney copper then your good.
Also search this site for the coil modification. It will get ~12 V to the coils. Check with a Multi Meter first to ensure you are not already getting 11.5 or higher V at the coils. If so then the mod is not necessary. If required, a 12 V auto relay some solder and an iron with male / female plug type connectors and wire will be needed. A cheap upgrade.
When I bought my bike it would not run and now it runs like a devil.
Yukabodos Buddy!!!
:blink:
Yukabodos Buddy!!!
:blink:
Last edit: 02 Nov 2009 15:11 by YUKABODOS.
- JonnyC
- fixer5000
02 Nov 2009 15:40
this is gonna be a nice project for jon. i went over and took a looky see today and his bike is all there. a very good start and he has some good ideas for it. with our assistance i am sure it will turn out pretty nice. jon remember dont get stuck ask for help when in doubt dont!! steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- JonnyC
19 Nov 2009 15:10
Bike never started after everything i did to it butttt,..............
check the update on my blog
futureuntold.wordpress.com/2009/11/19/she-roard/
1977 KZ650C
- JonnyC
20 Nov 2009 22:43
Did carb work, check here
futureuntold.wordpress.com/2009/11/21/ad...n-carburetor-county/
1977 KZ650C
