77 KZ650C Bobber Project
- JonnyC
29 Sep 2009 20:21
So i got the bike today, looks like i got A LOT of work to do, i need battery, headers, and the clamps. Start work on the engine and just check if it at least trys to turn on. Its not seized. Hoping i wont hav to do too much work with it.
1977 KZ650C
- JonnyC
Re: 77 KZ650C Bobber Project
03 Oct 2009 14:54
The pictures reinforce my opinion that anyone buying spray paint should be required to pass a psychiatric test first. He sprayed everything including the reflectors! I’m sure the bike will thank you when you finish cleaning and refreshing it. Be sure to change the oil (it may be as dirty as the bike) before you try to start it, and put some fresh oil on the cams and cam bearings if it's been sitting a long time. I'd also clean the tank and carbs and put on an inline fuel filter so you don't suck gunk into the carbs once they're clean. Good luck with your project, these bikes are pretty tough so you should be ok. Ed
- JonnyC
03 Oct 2009 19:53
650ed wrote:
Yeah i did not like the fat they spray bombed the entire bike. I will admit that i will do the tank and tins myself. but would make it look more professional than that. That is all great info that i will surely use before i attempt to start the bike.
1977 KZ650C
- Mellvis
04 Oct 2009 09:33
You can't go wrong with a 650 Custom. Clean the carbs, adjust and clean the points, lube the advance cam, adjust the cam chain and it will start. Always have faith in a 650 Kaw!
- Locozuna
04 Oct 2009 09:43
When my brother bought the 76 900LTD it had been fully painted about 5 times but not with a rattlecan. It was painted with a paint brush. Had bristles still stuck in the paint.
Couldn't tell today..
GLuck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- JonnyC
04 Oct 2009 14:57
Thanks.
Today was a sunny day, no rain so i went out to do as much work as i could.
Put on the header/exhaust
Can anyone tell me where to attach the exhaust too, im guessing maybe this exhaust isnt for my bike.
Took out the carbs, and airbox
Last picture, for this hose thats connected to the airbox, if i do pod filters would i have to get this hose its own pod filter too? Also this random metal piece i found inside my battery box. what is it?
1977 KZ650C
- Gorham
04 Oct 2009 15:11
JonnyC wrote:
I have the same situation with my 80' 650E1 project. The 4 to 1 isn't stock, so there's no tab or bracket to attach it to. I actually blew mine off the header when i was first getting the bike going. haha. my plan is to learn how to weld to i can make a tab for it. or you can get the orginal 2 - 1 for each side.
JonnyC wrote:
Looks like a bearing spacer for your (or an extra) back wheel.
- rstnick
04 Oct 2009 15:49 - 04 Oct 2009 15:50If i do pod filters would i have to get this hose its own pod filter too?
Yes, or a tube to vent it back and away from the rear tire.
I don't recognize the metal piece. Is it a tube? Got another picture of it from a different angle?
Attach the exhaust to the rear foot peg mount with a metal bracket.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 04 Oct 2009 15:50 by rstnick.
- JonnyC
04 Oct 2009 15:57
rstnick wrote:
thanks for the info. and no i have no other pics. its just a hollow metal piece.
1977 KZ650C
- JonnyC
16 Oct 2009 21:04
Got paid today and the whole thing went for parts on the bike. EBAY got pod filters, crankcase breather filter, k&n oil filter and a new repair manual.
pods wont be used till later in the project.
1977 KZ650C
- yuvalbo1
17 Oct 2009 10:49
cool man, what you plan on the Frame?
kz1000 1980
dr800 big 1992
camaro 1977
if you dont live on the edge you catch unnecessary place in this world.
yuval ISRAEL
dr800 big 1992
camaro 1977
yuval ISRAEL
