Sinners street/strip turbo project!!!!!!!!!!!!!
- PLUMMEN
Re: Sinners street/strip turbo project!!!!!!!!!!!!!
14 Oct 2009 17:20
will61310 wrote:
are we all happy now? :woohoo::laugh: :laugh: :laugh: Thanks for the different pic!!
- Sinners Saint
14 Oct 2009 20:15
Thanks 531blackbanshee, I'll keep this as a refference. I wanna see plummens pic sounds like he braced the shit outta his by the way you guys talk. Also I pulled the lower tree and stem fro my 80 model parts chassis, the necks loock the same on both the 80 and 77. I'm assuming that is true. The GSXR stem I have is very close to being the same O.D. as the kz stem. I slid the bearing from the kz over the gsxr stem and I bet it will fit. I need to mic them tomorrow. The stem nuts have the same size threads as well, only the kz uses one nut and gixxer uses 2. 'm gonna try to get my father in law to machine out the weld thats hold the kz stem in and press both stems out so we can see if the kz stem can be made fit the gixxer tree. Has anyone tried this? It looks as if the kz stem is pressed in from the top of the lower tree and then welded around the bottom of the stem. I know if it came down to it I'll probably have to have someone machine an entire stem to fit, my FIL does'nt have metric stuff to do the threads , so I'll have to find someone else here in Houston to do it.
- thompsonmx100
14 Oct 2009 20:23
i don't know if the stems are the same size but you should machine the weld off and press it out of the bottom. there is probably a snap ring on the bottom fo the gixxer stem. then you can either press in the kz stem or have bushing made to make it all fit. You haven't seen THE pic? from the looks of the frame bracing on plummens bike hes gonna throw a turbo viper motor in it. :laugh: keep on wrenchin
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Sinners Saint
14 Oct 2009 21:41
Ok so here is a few pics. I've been a bit lazy with the camera lately so there will be more, maybe tomorrow,lol.
This was the lower tree from the front end that the P/O had on the bike. Looks like all they did was spread the clamps out and jam the fork tubes in the. I chopped the lower tree apart and removed the stem, it's nowhere near being the right one for the neck of the KZ.
This is the gixxer front end just mocked up. I'm a little concerned it maybe to low when I get it finished.
Crusty, rusty and a lot of dusty, this shit is gone, my parts bike has some not so cancerous parts I'm gonna rob for this one.
- Sinners Saint
16 Oct 2009 22:34
Did some more stripping today, no not me you pervs, the kz. Anyway, I also decided to cut up the other kz frame I had for my bracing, beats going any buying tubing anyday. Finally got out the camera and shot some more pics of the madness that is my project.
First I'll show ya'll what I did for fun today...
I know theres a few die hards out there swallowing their tongues cause I cut up a KZ frame, LOL.
- Sinners Saint
16 Oct 2009 22:37
The harness on the 80 is in suprisingly good condition, all the plugs are there and they all disconnected from each other fairly decently. The Batery tray was'nt rotted or covered in corrosion so I'm putting it on the project.
- Sinners Saint
16 Oct 2009 22:44
Managed to remove the struts and swingarm as well. Sure seems to be made of some thin metal in my opinion. I may end up ditching it for a sturdier one if possible. I want to run shocks when I drive it on the street and this one would have to be modded for it to pivot like a stock swinger. I guess we'll see. I also need axle adjusters for this one. May have to have them machined. Would be nice with ecentric adjusters.
This is the suzuki wheel that was on it, its a 17x5.5. I have yet to see what the front sprocket looks like n this thing.
- Sinners Saint
16 Oct 2009 22:48Please Log in or Create an account to join the conversation.
- yuvalbo1
17 Oct 2009 10:21
cool project! Continue to update.
kz1000 1980
dr800 big 1992
camaro 1977
if you dont live on the edge you catch unnecessary place in this world.
yuval ISRAEL
dr800 big 1992
camaro 1977
yuval ISRAEL
- PLUMMEN
17 Oct 2009 16:09
- Sinners Saint
22 Nov 2009 15:25
Got my father in law to swap the stems for me. He milled off the weld on the kz stem and pressed it out ( presses up out of the tree). Made a bushing to press it into and then pressed it into the gsxr lower tree.
This is it with the upper tree I'm using
23 Nov 2009 13:37
lookin good!
how did you retain the stem in the tree?machined step,snap ring,set screw just curious.keep us posted,
