KZ1000 streetfighter project is finally complete
- dutchz
Re: KZ1000 streetfighter project is finally complete
28 Aug 2009 12:53
Galaxian, what tires are those? They look a little like race wets, I'm diggin em.
1974 Kawasaki Z1
Stock front hub and rear axle.
- chance
- Life long biker/
- mark1122
- Keep twisting it
28 Aug 2009 13:18
TerryK wrote:
Here is my project link. maybe it will be of some help.
kzrider.com/index.php?option=com_kunena&...w&catid=11&id=103381
a 530 and 630 are the same width. i used a 630. i heated the frames rail on the inside, with a torch and squeesed it with a c lamp for more clearance.mark1122 wrote:VERY NICE JOB!!:woohoo:
mine is allmost the same. i used the 95 forks. what do u mean by "no preload adj" ?
can u add details about the 6" rim fitment? did u use a zx11 caliper arm?
did u use a 5/8" offset sprocket?
i was able to gut and shim the stock chain cover, and use it with my 5/8" sprocket.
Did you have to go to a 530 chain for frame clearance?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
30 Aug 2009 04:23 - 30 Aug 2009 04:24
galaxian ,did u use all zx7 parts at the rear, or did u mix zrx and zx7? cal arm, cal, rotor, shims????
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 30 Aug 2009 04:24 by mark1122.
- Old Man Rock
30 Aug 2009 05:30
Tears of joy!... Seriously, that is freaking BEAUTIFUL!
Larry C went ZX-7 on the back as well and in speaking with him, what a job it was to get it to all work... Hell, I thought I had to do some fabbing with my ZX-6 setup....:blink:
You're going to really love the updated suspension especially on winding/twisty roads. Just lean and she'll follow.... My buds on all their new bikes still can't believe how the old girl responds and rides... They still shake their heads in disbelief.
The updated brakes make one hell of a difference when a damn coyote runs across the road! :laugh: Or when some ass wipe is on their frigin cell phone trying to text message...
Anyhoot, phenomenal job you accomplished on the old girl, looks killer and will ride so smooth you're going to get a woody. :blush: Don't ask how I know this fact... :laugh: :laugh: :laugh:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- galaxian
31 Aug 2009 05:49
DutchZ the tires are dunlop D616. I thought they looked like rain tires as well.
1977 KZ1000A1, 1979 KZ650 C3
- galaxian
31 Aug 2009 05:52
mark1122,
the rear is as follows:
swingarm ZRX1200
Rear wheel is a zx9 6"
Caliper is ZRX1200
Brake arm is a ZRX at one end and cut and welded FZ700 at the caliper end.
I made the rear wheel spacers but still need to perfect them. I am going to machine some aluminum ones that look and fit better then the current steel ones i made before.
swingarm ZRX1200
Caliper is ZRX1200
- Bad Kaw
- Flying Squirell
01 Sep 2009 21:44
OUTSTANDING!
-KR
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- mark1122
- Keep twisting it
02 Sep 2009 19:58 - 02 Sep 2009 20:05
i have heard that a zx11d caliper arm will fit.
i think i will change to a 1/2' offset sprocket , so i can fit in an O ring chain.
my heavy duty 630 chain is stretching like crazy.
I just realized that since my swing arm is lower than it should be,(about 3.5" due to the shocks being too long) it is stretching the hell out of my chain. As the shocks compress over a bump , the chain gets tighter. If I adjust the chain to have 1.250" of slack and then compress the shock 3", the chain is sprung very tight. This explains why my chain has stretched sooo much. i may need to take out a link:(
Looking at your pic, i'd say u are going to have the same trouble. how long is your shock? mine is 14 1/8".
try putting the bike on a jack, remove the lower shock mont bolts, lower the bike to act as the shocks are compressing. now watch the chain to see how tight it gets as u lower the bike. Just a heads up bud. maybe yours is just fine?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 02 Sep 2009 20:05 by mark1122.
- galaxian
03 Sep 2009 06:10
Mark1122 i will take a look. So what kind of a solution do you have for this problem? This is an interesting issue.
- loudhvx
03 Sep 2009 10:12 - 03 Sep 2009 10:16
That is really sweet looking. Can't wait to see it at Mods next year! Very nice job Greg.
So when do we get to wire it for kick only and ditch the battery?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 03 Sep 2009 10:16 by loudhvx.
- galaxian
03 Sep 2009 11:39
loundhvx,
i am old i really like my push button starter. :)Actually i want to split the cases and remove the kicker completly but that is a whole other project. HHHHmmm i do have a cb750 project that i could do that too. I may take you up on that offer.
My honda could use some electrical love since i am electrically challenged. Can i pay in beer and bike parts?
