KZ1000 streetfighter project is finally complete
- 01kz1000p
Re: KZ1000 streetfighter project is finally complete
19 Aug 2009 11:30
NICE CLEAN Job Galaxian! BTW, I an new to the forum and like everyone else here.. I own a Kawi (KZ1000p). The bike is going trough a chop bob work (rigid frame) rtnow. I got an 06 Kawasaki 636R front end (gold nitrite colored forks). Kind want to keep the the stock kz1000 mags for the rear end. But my buddy suggested to go with a sports bike 160-170 tire rear end.
My questions to you:
1.) the zx front end you got mated to your kz1000, did it bolt on wit no fuss??? what trouble and adjustment did you have to do?
2.) for the drive sprocket, did you purchase an offset sprocket to make it work with the rear end?
Much appreciate it Amigo, Thanks!
- galaxian
19 Aug 2009 12:41 - 19 Aug 2009 13:18
The front end was actually fairly straight forward. The ZX7 stem ID is the same as the KZ1000 stem OD. So i cut the ZX7 stem right at the triple and pressed in the KZ stem into that. Welded a bead on the bottom for good measure. Done.
I do have an offset front sprocket its a 5/8 offset. The rear weas fairly complex in the sense that i needed to offset the front sprocket so the chain would not hit the new 180 tire and at the same time machine down the rear sprocket carrier so that the chain does not hit the frame. I have a diagram somewhere of all the measurements which i can post once i find it. It took lots of measuring and checking websites for the correct sprockets. However if i had to do it all over again i would go with a 5.5 inch rim in the rear instead of the 6 rim that i did. You can still fit a 180 tire but have some breathing room for the chain.
1977 KZ1000A1, 1979 KZ650 C3
Last edit: 19 Aug 2009 13:18 by galaxian.
- 01kz1000p
19 Aug 2009 13:09
Appreciate it Bud. I did come across a post and a link regarding a kz1000 and zx636r front end swap. And you practically did the similar thing by reusing the kz stem. I hope there wont be any major diff from using the zx7 vs zx636 forks. I'm assuming you got a 16 in rim for front?
did you custom made your own offset sprocket? I'm lookin at D&G sprocket and cover but none of the support guys from the store can help me with the right matching combo, rear end rims to sprocket offset setting. To be honest I got more info from you!
I should be taking pix soon here, we got three more bikes to complete prior to my build in the shop.
Thanks BUD!
Thanks BUD!
- galaxian
19 Aug 2009 13:19
PMFR for offset sprockets and my front rim is a 17 not 16.
- oldirtybob
19 Aug 2009 13:30
That's bad as fu*k. Old school style with new school tech, love it. About how much time/money invested including original bike?
- 01kz1000p
19 Aug 2009 14:09
Appreciate the info G! Now, back to Ebay for me to look for rims fo the build. Wire rims is nice... checkn out Black Bikes dot com for custom wire rims. :woohoo:
- larrycavan
- Zedone
23 Aug 2009 23:34
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- Headly
24 Aug 2009 03:41
Thats a gorgeous looking bike mate,i love the look of old skool style with modern suspension,wheels etc....:woohoo:
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
- galaxian
24 Aug 2009 13:25
Thanks Guys!
- mark1122
- Keep twisting it
28 Aug 2009 06:53
VERY NICE JOB!!:woohoo:
mine is allmost the same. i used the 95 forks. what do u mean by "no preload adj" ?
can u add details about the 6" rim fitment? did u use a zx11 caliper arm?
did u use a 5/8" offset sprocket?
i was able to gut and shim the stock chain cover, and use it with my 5/8" sprocket.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- TerryK
28 Aug 2009 10:17
mark1122 wrote:
Did you have to go to a 530 chain for frame clearance?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
