KZ550 powered YZ125 project
- nelson8708
24 Jun 2009 16:52
So a sour deal on a yz125 and lack of interest in resale have pushed me into a new project. I am going to build a super moto style bike for the street using a kz550 to power it. I found a wrecked 1982 kz550 in the local craigslist and decided to pick her up. I striped the bent frame of all its parts and that is where i am at now. I have a 96'yz125 that i have striped to the bone in order to get it ready for the kz550 heart transplant. I have weights the yz and kz engines to find that the kz(146lbs) weights 103lbs more than the yz(43lbs). I'm sure i will have a lot of electrical questions since i have to wire the bike from scratch along will quite a few engine questions i'm sure. The only two other bikes i have owned was a 1981 honda twin star and a 96' ninja 600r both of which never gave me any problems so working on bikes is something new (I work on cars a lot). Any way here are a few pics of everything.
^got a set of carbs off ebay along with an igniter, rectifier, starter, starter solenoid
^pulled the vc to check valve clearance and man it was clean in there. (exhaust .004 intake .003) Over winter i will loosen up the clearances since i only plan to put 1K miles on it this season depending on when i get her done.
^from this to....
^....this in a couple hours
I'm hoping to get her mounted in the yz frame this weekend. Any one have a good idea on how to line up the sprockets when i mount her? I plan on using a string tied to each sprocket for a straight reference point.
Comments, critizm, opinions welcome
-Nelson
^from this to....
-Nelson
1996 yz125 power with 1982 kz550 engine
1989 240sx Turbo weekend warrior
1993 Civic daily beater
- nelson8708
Re: KZ550 powered YZ125 project
25 Jun 2009 18:06
Progress anyone??? The first cut was the hardest because after that there is no turning back.
A little bit of trimming and the tank and ex-radiator shrouds will fit.....going to keep it looking some what like a dirt bike.
- DrWhizBang
25 Jun 2009 18:53
Dude, you are out of your mind! I can't wait to see how this turns out
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
- nelson8708
29 Jun 2009 03:51
I got it mounted in the bike but, i need to remove it to do some final welding on the areas i couldn't get to. I also ground down my thumb in the bench grinder accident. So now i have blood, sweat, and i'm sure tears will follow some time during the build. Probably when i get my credit card bill for this past month will all the part purchases i made. I'll get some pics of the bike later today.
- Wildh2oskier
- nelson8708
29 Jun 2009 19:08
Pictures.....
^mocking up the front tubes
^bench grinder accident :blush:
^electric tape bandaid ftw!!!!
^this is where i started today
^this is where i finished....i had to remove the engine for final welding
I still have a couple more braces i want to make before i put the engine back in for the last time. Its sucks getting it in and out but, now i need to make new gas tank mounts since the stock one wouldn't allow me to remove the engine....Its getting there
29 Jun 2009 19:35
Excellent fabrication, and a most interesting thread.
Was wondering how the down tubes would be added.
Very sanitary work!
Thanks for all the pics!
Ain't got time to bleed! :woohoo:
Good Luck!
Very sanitary work!
Good Luck!
- eyeofthestorm
- its KZ kraziness!
29 Jun 2009 21:12
this is so cool! as far as exhaust 4-1 would be the way to go, or you could aways build your own header and run a midpipe to a can up by the back fender. wicked! this things gonna be nuts haha
- nelson8708
30 Jun 2009 03:55
I'm probably going to just go straight pipes since it will be the easiest for me to make. I'm keeping an eye out on ebay for a smashed up header to build off of. I need to pay off my credit card before i buy any more parts though. The next thing i'm buying is a battery so i can build a battery box and start my electrical work.
- WPBill
30 Jun 2009 12:14
AWESOME! You da man!
You can only be young once, but you can be immature forever!
Kamakura JAPAN, 1975 Z1B (x2, both in storage)
- nelson8708
01 Jul 2009 22:00^gutted for some paint
^some of the bracing i added
^trimmed the gas tank to clear the carbs.
So now has come the point where i have a few questions. First is i plan on gutting the stock air box and putting the battery in there along with the rectifier and igniter. I was wondering if the igniter and rectifier need to have air flow over them or if they are inside the battery box (gutted yz airbox) will they be ok? Also, now that i have trimmed the gas tank to clear the carbs i need to figure a way to seal up the huge hole in the bottom of the tank. I went and bought a plastic welder from harbor freight and i dont know if its the welder or just maybe i cant weld plastic but, it didn't work very well. Is there anywhere i can send the tank to get it finished?
- Kawickrice
01 Jul 2009 22:18
I used to ride a friends RM465 and that bike was wicked fast. That looks like it will be a blast to ride.
If your tank is ABS plastic, there is a kit called Hotcha Repair Kit from the Vetter fairing website that might work. The only place to get it supposedly.
craigvetter.com/pages/Online_Store/Online_Store_main.html
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
