Restoration of a 82 Z1000j1
- biker4life
- Once a biker always one
03 Apr 2009 09:58
Could some one please help me I am restoring my Z1000j1 and i would like to put a wider tyre on my bike which is the best swing arm to use with out any complications
- speedadict
Re: Restoration of a 82 Z1000j1
03 Apr 2009 10:06
Without any complications? Theres the catch...
- biker4life
03 Apr 2009 11:02
so you mean that i would have to cut it to fit
- Mcdroid
- Gone Kwackers
03 Apr 2009 11:12 - 03 Apr 2009 11:12
No, I think he means that if you are restoring it, then stock tires would be best (4.25X18). Anything wider tends to rub...you can put a wider swingarm in that accepts a wider tire but it will take a bit of work to adapt it.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 03 Apr 2009 11:12 by Mcdroid.
- biker4life
04 Apr 2009 09:36
Yes i want to put a wider swingarm to take a wider tire any ideas out there as to which is the best swingarm i can use that will take a 17"rim
- biker4life
04 Apr 2009 09:38
Hi all just want to let you know i am from South Africa
- biker4life
04 Apr 2009 09:51
I would still like it to have the double shocks at the back so all help is needed in this.
- jtmcculloch
04 Apr 2009 09:55 - 04 Apr 2009 09:57
dont forget you might need an off-set front sprocket and maybe a differant drive chain to match the rear sproket.
76 KZ1075
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
Last edit: 04 Apr 2009 09:57 by jtmcculloch. Reason: more info
- kztee
- TeeRoy
04 Apr 2009 12:33
Use the search function and do some research throughout this forum. A gs 1100 swingarm from the early 80's seesm to be widely accepted as a good choice.
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
- Z1109R Fin
08 Apr 2009 04:20
S E A R C H -function is very helpful. Plenty on J/R -frames out there with swapped swings. My ELR now has a ZRX1100 ´98 rear and Öhlins dual-shocks. You can find the whole story here on "Projects" -> "Swing swap....."
Z1000R ´83...Slightly modified...
- arai59
08 Apr 2009 04:36 - 08 Apr 2009 04:37
I believe a FJ1100 swingarm might work also. And welcome. Pics are a must.
Last edit: 08 Apr 2009 04:37 by arai59.
08 Apr 2009 08:13
z1000j you say,south africa, you say,wider swingarm,welcome,we can and will help.
check out roynor's(kzrider member) project thread.he is installing a suzuki tl 1000 swingarm on his z1000j.there are several swingarms that can be modified to work and as has already been suggested the search function should reveal lots of info.
z1109rfin has a thread on his bike and he installed a zrx 1100/1200 swingarm.
i took the raod less traveled and custom built my own swingaram out of 4130 cro-mo,to accept a 2000 r1 rear wheel and tire and brake system.i too kept the dual shocks.
hth,here is my bike.
leon holmes
leon holmes
