1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
  • Tylerk1001
  • Tylerk1001's Avatar
Re: 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
28 Sep 2015 16:31
#692404
I am newbie and then some when it comes to Kz"s and motorcycle customization but I have spent the last few days reading every little bit of this entire thread. I am astonished at the level of attention to detail put into this bike. This is the most Beautiful motorcycle that i have ever seen. If someone was to put it beside others in a show and not having read this i might be compelled to think another bike is more beautiful but after reading this and feeling that i am a part of this somehow by being happy with you through your success and down right angry with you through your heartaches. No other bike comes close! You did a phenomenal job that i only hope to get close to once i start my build. I look forward to future builds from you. Thank you for taking time to document this build so well and letting us be part of it.
The following user(s) said Thank You: tk11b40
  • tk11b40
  • tk11b40's Avatar Topic Author
29 Sep 2015 18:38
#692561
Wow.
I am humbled by your compliments. Truly. Thank you. I enjoyed the journey, although came very close to dragging it behind my pick-up down the street a few times.
The whole story is pretty cool, even now that the bike has a new owner. The new owner and I text each other a few times a week, he is talking the best possible care of the bike and has put about 800 miles on it since he purchased it. Your compliments are taken to heart. My favorite inputs come from other riders who are are want to build a bike.
The new owner has many of the same compliments, the detail he says is pronominal. It can torture you this sense of perfectionism. When I get a compliment like the one you have posted, makes it so worthwhile.
Thank you very much,
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • tk11b40
29 Sep 2015 18:47
#692562
MAR:
Buy a regular drainplug and a round magnet that is smaller diameter than the threaded end preferably about half the diameter.
I will chuck the drainplug in the lathe, and bore a hole for the magnet.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • MAR
  • MAR's Avatar
30 Sep 2015 14:19
#692669
Can someone take a picture of how the under seat locking mechanism is fitted?
TK, thank you for the offer. Much appreciated.
1975 KZ 900
1975 Laverda 750 SF 2
1978 Harley XLCR
1982 Laverda 1200 Mirage TS
1995 Ducati 916 Superbike
2001 Aprilia Falco SL
2004 Triumph Thruxton
2012 MV Agusta F4R
  • MAR
  • MAR's Avatar
26 Oct 2015 16:33
#696072
So the time had come to make changes. I have about 1300 miles on it now . I have a 530 chain and have geared it up back to normal. Still trying to get a counter sprocket with the correct spacing to clear the wider tire . Sprocket specialist helping .
Also tried to install Woodcrafts clip ons . However the risers hit the pinch bolts on the triple tree. . Need to find 7/8 inch bar clamps to fit normal bars. Clip ons may not work.
Finally the bad news is my buddy was riding the bike . He was losing balance and turned the handle bars jamming them into the steering lock. Broke the stop and dented the tank. I need to find a way to make strong steering locks and repair the tank.
1975 KZ 900
1978 Harley XLCR
2012 MV Agusta F4R
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
27 Oct 2015 03:55 - 27 Oct 2015 04:03
#696109
sorry to hear about the friendcident those can be painful :whistle: .
www.outlawracingproducts.com/clampsmounts.html
Last edit: 27 Oct 2015 04:03 by 531blackbanshee.
The following user(s) said Thank You: MAR
27 Oct 2015 05:10
#696117
That's the main reason I let no one ride my bike. Accidents can happen, but if someone damages your bike you feel bad about it and they feel bad about it. I let a friend ride my BSA once. He went about 30 yards before he crashed through a stand of small trees. :S Oddly enough, the bike wasn't hardly damaged, but he looked like he had been through a chipping machine. Lesson learned. Ed
  • tk11b40
28 Oct 2015 18:04
#696346
Oh boy.
Well. Shit.
That is going to be tough to fix. The steering stop broke away for the lower triple clamp I am assuming. The clamp is from a GSXR 1100. Perhaps this would be a good time to machine billet triple clamps. I can talk with the programmer at work who may do them after hours.
He is gonna be 30 buck an hour. You already have the painter contact info. This is a shame, the tank is brand new.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • MAR
  • MAR's Avatar
29 Oct 2015 06:50 - 29 Oct 2015 11:27
#696398
Yes I have spoken with Gary. He is happy to repaint the tank. I will take it off this week end and drain the fuel and mail it to him. i will go up there to pick it up when it is done.
I was thinking a fix for the stops might be to tap little bolts into the lower triple tree and just screw little bolts into to them. Thoughts?
Or welding material to the triple tree and getting it powder coated again.
I had to send the counter sprocket back to Ut so they can get the spacing correct for the 530 chain.
Also as long as the rear wheel is off I am getting a new tire.
Finally getting the bar ends opened up a bit to fit bar end mirrors.
Next up a Corbin seat and a steering damper.
1975 KZ 900
1978 Harley XLCR
2012 MV Agusta F4R
Last edit: 29 Oct 2015 11:27 by MAR.
  • tk11b40
29 Oct 2015 08:23
#696410
The triple tree is most likely Die Cast, therefore very difficult to weld. I have a good friend who has tig welded die cast for me in the past and been successful. Welding is a strong possibility. The otehr problem is getting the steering stem pressed out of the clamp, which should be done at a good shop. The triple clamp will need to be warmed, then press out the stem. The stem was built by Kossman.... $$$$$$$$$$ ! do not damage that while trying to weld or press it out of the clamp. I think it was somewhere between 250 and 400 clams. Its custom made by Kossman.
Can you send or past a photo of the damage?
When you come over the hill to pick up the tank you should stop by, we can figure out how to fix the steering stop, and possibly make it better in the process.
I can also measure thee triple clamp on the CMM and reverse engineer it. Then we can talk with my programmer to see what he would want to machine one out of billet.
Do not get discouraged, these things happen and are often a chance to make the bike better.
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
  • baldy110
  • baldy110's Avatar
29 Oct 2015 08:40
#696414
What tk11b40 said, I use accidents as an excuse to make the bike better. For example, in 2010 I did a "spare no expense" re-build of my KZ650, it came out beautiful. However there were items that bugged me that I did not consider until after it was finished. I rode it for less than 500 miles and got into an accident on the I-14 to I-5 interchange in California, (Stupid cell phone users). That accident totaled the bike, I dragged the bike home and re-built it again but this time I fixed everything that bugged me and now it's exactly what I have always wanted. Just don't get bumbed out by it and move on.
2010 re-build, pre-crash
[IMG
500 miles later, crash
[IMG
2012 re-build
[IMG
  • MAR
  • MAR's Avatar
29 Oct 2015 10:10
#696422
Badly, beautiful bike! Yes this is an opportunity to "further develope" a wonderfully crafted bike.
This mishap is just fine with me. I can only assume it hurts TK11B40 more than me.
Don't worry TK, the bike will get what it deserves to be right.
1975 KZ 900
1978 Harley XLCR
2012 MV Agusta F4R
