Bike running Boat not (so good)
- Iron Duke
- what are you rebelling against?
11 Mar 2009 14:22
Hi guys I'm back , and have that KZ 550 running great after changing petcock, little sea foam, deep creep,but thats not why I'm posting! 2yrs ago bought at an estate auction a 73 deck boat for fishin(and speedin)it also had a 73 mercury 500 thunderbolt 50 horse motor. Have had it out on water twice,both times after priming was hard starting (plugs checked and cleaned)after starting hard to keep idling without using choke, And under load dies or NO POWER lucky if it moves at all, pee hole is putting out water, have ordered the service manual,not here yet, and knowing how smart my fellow brothers are at KZR thought i would just throw this out let you all kick it around see how many IDEAs come back small engines to small engine, I think its carb related but from what Ive been told it could be a few other things. help me out here guys and help me get it runnin right, then next time your in the neighborhood we can ride out to one of out lakes,fish,boat ride, picnic,and party. in advance thanks guys I'll be watching!!!!
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- Mark Wing
Re: Bike running Boat not (so good)
11 Mar 2009 16:24
I think that's a 2 stroke motor. If so you may want to check out the reed valves.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- timebomb33
11 Mar 2009 16:32
one other thing to look at is your crankcase seals take it to a boat place and get them to pressure check the bottomend or if you have a good buddy that has a 2 stroke pressure tester throw him a few pepsi's and i'm sure it wont take long sounds like the typical crankcase leak to me. in a two stroke there are 2 kinds of compression primary and secondary primary compression takes place in the bottom end or crankcase, secondary takes place in the cylinder. primary compression is always higher
I THINK MY POWERBAND BROKE
- PLUMMEN
11 Mar 2009 17:44
just wondeing,how much speedin do ya do with 50hp?:laugh:
- Iron Duke
11 Mar 2009 17:50
Plummen.....thought groucho marx had passed on....Welcome back Groucho
1982 KZ550 LTD C-3
- Iron Duke
11 Mar 2009 17:54
Should have asked how BIG is boat how many #s are you pu shing how many people doe's she carry ect ect ect She should go bout 45mph
1982 KZ550 LTD C-3
- Iron Duke
11 Mar 2009 17:56
maybe little more in top tune, had a Johnson 65 with 300 more pounds in hull that topped out at 60-65 mph
1982 KZ550 LTD C-3
- PLUMMEN
11 Mar 2009 20:46
- PLUMMEN
11 Mar 2009 20:58
