KZ 750 L3 Project finally runs (Vid clip)
  • Grantl
  • Grantl's Avatar Topic Author
  • KZRider is Da Bomb!!!
01 Mar 2009 12:17 - 01 Mar 2009 12:27
#268974
Well folks,
I finally got her running after chasing a suspected vacuum leak for ages. Turned out that the replacement throttle cable was just a bit too short (how dumb does that make me feel?). Ended up trimming the twist return stop to create more cable return movement--problem solved. She stumbles below 3000 RPM's but runs great above that. I know I have at least 1 bad vacuum diaphragm but will have to save up for 4 replacements from the U.K (cost 150-200 bucks with shipping).
To date I have replaced the petcock, new carb to airbox boots, carb holder mounts, speedo console and side covers off craig's list. Carbs in and out of the bike multiple times. I also picked up a complete extra motor for 30 bucks off CL. Look at how close the front fender is mounted... The P.O. must have mounted an oversized front tire. I have been taking short shakedown rides to see where the bugs are, so far, nothing serious. Check out this short vid and share your comments. Thanks Grant.
(Youtube)
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
Last edit: 01 Mar 2009 12:27 by Grantl.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: KZ 750 L3 Project finally runs (Vid clip)
01 Mar 2009 12:36
#268975
thats great grant...that frame and set up habdles really good...when you get it all dialed in your gonna have a fun bike...same geomtry as a elr1000....videos are great thanks...nice 30$ motor too
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
