kz1000 street/drag build
  • jordan
  • jordan's Avatar Topic Author
Re: kz1000 street/drag build
19 Dec 2009 16:40
#339889
Quick question for those of you who are bracing their frames. I circled the areas where i am thinking about removing. What is the tab with the wing nut for? also, is the farthest left bar going across just for the inner fender mounting? I plan on making my own inner fender and mounts so i wont need inner fender mounting tabs. Then lastly, is the area between the duck tail mounts also for the inner fender? I would like to cut this out too if its not necessary.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • PLUMMEN
  • PLUMMEN's Avatar
19 Dec 2009 19:23
#339906
the lower brace directly behind motor is where your stock battery box mounts on kz,z1s dont have it .i think it actually helps stiffen things up.if you remove the rear fender mount between shock mounts id suggest replacing it with something smaller maybe that doesnt interfere with what you have inmind.im drawing a blank on that wingnut! :woohoo: as much power as youre adding i wouldnt worry too much about that little bit of weight youre talking about B)
  • jordan
20 Dec 2009 03:54
#339929
alrighty, thanks. as for the wingnut i have no clue either. i bought the bike already torn down so i have no idea what it was used for. amlost certain it is stock, and was not added by the PO though
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Dec 2009 06:16
#339948
Nice to see progress there, Jordan. That setup is going to look wicked.:woohoo:
as for the frame Questions, Sorry i cant help. for some reason that frame pic is way dark on my screen. it starts to load ok (bright and clear) , then goes dark and i only see the white outline??? Anyone else have this issue?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • StreetfighterKz
  • StreetfighterKz's Avatar
20 Dec 2009 18:31 - 20 Dec 2009 18:31
#340065
The tab, with the wingnut, is for a securing the airbox silencer.
If you remove the brace toward the rear, you should probably replace it with something smaller.
The front lower brace, as said before is for the battery box.
Are you planning on running some type of rear suspension? If so think about your tire rubbing the rear loop on the frame when the shock(s) are compressed. I had to redo my whole rear frame section on my 900 project.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 20 Dec 2009 18:31 by StreetfighterKz.
  • jordan
20 Dec 2009 23:30
#340111
Later, Doug
thanks for identifying the wing nut deal, and as for suspension i will be running struts so i shouldnt have too many problems
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
