kz1000 street/drag build
  • Old Man Rock
  • Old Man Rock's Avatar
Re: kz1000 street/drag build
14 Jun 2009 13:46
#299128
Here's another but H2, Las Vegas... Insane I tell ya...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
15 Jun 2009 04:13
#299321
No problem Jordan. I have a spare 1327 setup.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • jordan
  • jordan's Avatar Topic Author
15 Sep 2009 22:48
#321927
won this item. Almost ready for bottom end to come together. Need HD 2nd gear, and upper cases bored for the big block
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 Sep 2009 07:53
#321959
Nice to hear that things are moving forward.B)
Have a good look at the springs at the back the basket. Make sure they are tight and in good shape. u can replace them if they are worn bad.
i found a peice of a spring in the bottom of my motor once. this was what lead me to find the issue.
i bought the APE springs and repaired it repaired. not dificult at all.B)
i can walk u through it if neaded.
U will want a suport plate for the output shaft sprocket as well.
B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • PLUMMEN
  • PLUMMEN's Avatar
16 Sep 2009 08:39
#321968
the big hump in the clutch cover tends to give away too much info! :laugh:
  • jordan
16 Sep 2009 10:10
#321989
haha, ya that sprocket cover kinda hints that the bike is not stock. But the long and low stance i am going for should do a good enough job at suggesting that this old boat anchor may be a handful to mess with B)
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • racer54
  • racer54's Avatar
16 Sep 2009 14:53
#322032
They make a spacer that bolts on to the cases between the cases and the stock clutch cover that clears the lock-up. Paint it with the motor and unless you know it's there, it is hard to tell. Not sure if they still make them but they are out there. I think MTC makes them. That way you wouldn't give away what you are doing.
  • timebomb33
  • timebomb33's Avatar
16 Sep 2009 18:35
#322074
hey jordan you will have to get button's installed in your pressure plate idf your going to use that lock-up. eventually the lock up arms will work there way thru the thin alluminium pressure plate just something to watch out for. i speak from experiance.
I THINK MY POWERBAND BROKE
  • jordan
16 Sep 2009 22:24
#322124
Do you have a picture of these buttons that you are talking about? I have the whole clutch setup with the lockup that was used on a dragbike
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • timebomb33
17 Sep 2009 21:13
#322304
i don't have any pictures but you may be able to get pictures from m.t.c or schnitz
  • racer54
  • racer54's Avatar
17 Sep 2009 22:49
#322319
If you go to the Schnitz site and look under clutches, they have a couple pictures. I tried to put them up but they wouldn't allow copying the pictures. Basically, they just machine the pressure plate and press in a steel button in the area where the arms of the lock-up presses on the pressure plate to keep the arm from digging into the aluminum of the stock plate.
  • racer54
  • racer54's Avatar
17 Sep 2009 23:53 - 17 Sep 2009 23:55
#322325
Here's a picture of a pressure plate with buttons installed. Not sure what this one fits but this is what it is and looks like.
Last edit: 17 Sep 2009 23:55 by racer54.
