SERIOUSLY worked frame....
- caffcruiser
27 Nov 2008 11:43Still needs more smoothing, but that's it.
I removed 2" from the length of the subframe, removed the "kick" in the subframe to make it totally flat, and repositioned the drop tubes from the shock mounts to the drop rails. Added a small triangular gusset to take up the space and clean it up a bit.
All that to make the tank and tail level.
- kano
- Not Another Bloody Limey!
- Wildh2oskier
Re: SERIOUSLY worked frame....
27 Nov 2008 14:10
If you put the work intothe motor and suspension you have into the frame then this will be a cliche' racer worth taking a look at.
- PLUMMEN
27 Nov 2008 14:30
- Old Man Rock
27 Nov 2008 15:18
Me likey!
Nice welding job!
OMR
Nice welding job!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- caffcruiser
27 Nov 2008 16:56 - 27 Nov 2008 16:57
Thanks guys. I was thinking of putting the stock 650 back in it just for something this summer, but I've got plans for something a little crazier in the works too....
Suspension on the other hand is taken care of. I've got a spare GSXR front and rear end laying here from another project that are already converted to KZ spec to use on a 650 frame.
Last edit: 27 Nov 2008 16:57 by caffcruiser.
- guitargeek
30 Nov 2008 13:32
Dude, that looks tough! You doing any more gussets? How about beefy engine mounting bolts?
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- galaxian
01 Dec 2008 07:31
Is that a GPZ tank on there? Looks very nice. And what seat is that? Details sir...details!
1977 KZ1000A1, 1979 KZ650 C3
- caffcruiser
02 Dec 2008 02:59
Thanks Justin! I don't think I'm gonna go to much further with the gussets and stuff. It will get one lateral on it under the seat, but that's it.
Galax, yup. that is a GPz tank. I had to cut off the rear tank mount from another frame, turn it backwards in relation to the front of the bike, and weld it to the stock mount to get it on there.
The tail piece is from Glass From The Past. It's called the "slippery sam". It's almost 100% perfect... just needs a spacer under the back corner to level it out.
Thanks!
Thanks!
- galaxian
02 Dec 2008 07:18
CC,
great job!! How about a pic of the tank mount. I have always been partial to the gpz tanks myself so this could really help...pretty please.
- henrymski
- caffcruiser
