time on my hands soooo
- fixer5000
18 Oct 2008 11:04
i did my valve clearances, stripped and ultrasonicly cleaned my carbs, rebuilt the set, installed dyna coils and wires and put it all back together. this was supposed to be a winter project but you all know how that goes right?? suprisingly i only had to adjust synch on the two outter carbs!! gotta love that...steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- fixer5000
Re: time on my hands soooo
18 Oct 2008 11:04
massachusetts
massachusetts
- fixer5000
18 Oct 2008 11:05
massachusetts
massachusetts
- fixer5000
18 Oct 2008 11:06
massachusetts
massachusetts
- fixer5000
18 Oct 2008 11:07
massachusetts
massachusetts
- rstnick
18 Oct 2008 11:15
Nice work!
With all that time on your hands, you wouldn't happen to be coming up this way would you? :laugh:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Oldwolf
18 Oct 2008 11:39
Can you share some more info on the Vac gauge set you built. Would love to see more pics and a parts list of how you put it together.
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
- fixer5000
18 Oct 2008 13:06
sure!! what your looking at is 4 1/4" npt industrial vacuum gauges, 4 1/4" npt brass short elbows,4 1/4"npt and 6mm inlet smc flow control valves ( snubbers ) 4 6mm to 8mm adaptors 4 8mm straight unions with check ( you dont really need it to check ) and a bunch of 6 and 8mm urethane vacuum or air hose also smc. you can get all this stuff from any motion industries or bearing house usualy or use what ya got. i made this thing about 15 years ago. all the fitting are the push type and good for pressure or vacuum. they dont leak a bit. learned about these from work. im gonna guess this whole thing including nails lol cost me about 60 bucks to fab up. the trick to this is to get 4 gauges that are exactly the same and if theyre not youll have to tweak the bourdon tubes until they are. if you have any more questions please ask...steve
massachusetts
massachusetts
- fixer5000
18 Oct 2008 13:08
massachusetts
massachusetts
- fixer5000
18 Oct 2008 13:08
massachusetts
massachusetts
- fixer5000
18 Oct 2008 14:30
rstnick wrote:
not unless im riding my sled rob
Nice work!
massachusetts
massachusetts
- timebomb33
19 Oct 2008 00:46 - 19 Oct 2008 00:47
hey how is the bike running the reason i'm asking are those numbers that on the first picture the bike is pulling for vacuam it seems kind of low i always personally shoot for as close to 20 inches on a set of sticks i've never used gauges before always sticks is there a differance in readings. by the way those gauges look pretty trick.
I THINK MY POWERBAND BROKE
Last edit: 19 Oct 2008 00:47 by timebomb33.
